Rocker bolt. says 22lbs tq. 25lbs okay?
Old 07-09-2005, 10:19 AM
LS1FIRE's Avatar
Default Rocker bolt. says 22lbs tq. 25lbs okay?
I am curious if it will be ok if i torqued the rocker arm bolt to 25ftlbs instead of 22 lbs? I read to tq it down to 22ftlbs from ls1howto. Also is there a toque sequence? Thanks
Old 07-09-2005, 10:24 AM
HAMRHEAD's Avatar
25 is fine. JMX says 22 - 24ish on ls1howto so I don't think 25 will hurt. There is no sequence that I am aware of either.
Old 07-09-2005, 10:25 AM
4mula's Avatar
i have mine set at 22.
Old 07-09-2005, 11:32 AM
Predator's Avatar
If you're using an extension on your torque wrench, you might want to add a few pounds anyway.
Old 07-09-2005, 02:22 PM
Fade2blk500's Avatar
I'd do the suggested 22 and not a lb over, those rocker bolts are real prone to taking a crap.
Old 07-09-2005, 03:23 PM
02RedHawk's Avatar
25 is fine. Don't even worry a lick.
There's probably more people on this board than we think that don't even use a tq-wrench.....
Old 07-09-2005, 07:52 PM
HavATampa's Avatar
Talking
LOL! True. Scarey, but true. With all the post I've seen lately on "How to fix my stripped threads?", I believe it. It's more important now than ever before with these all aluminum engines to use a good torque wrench. LS1fire, you do realize that torquing to 25 ft. lbs will not benefit your setup in any way. Curious as to why you want to go over 22 ft. lbs? Not saying don't do it, just wondering.
Old 07-09-2005, 08:31 PM
Lost's Avatar
Yella terra recommend 25 lbs,so I dont think it would make much of a difference, I do mine twice with a short motor spin in between, just be sure to pull the fuel pump fuse..
Old 07-09-2005, 08:59 PM
LS1_PNYTAMR's Avatar
i did 23-25
Old 07-09-2005, 09:04 PM
gomer's Avatar
I always do them 25ft/lb and work my way from the center out. I'm not saying it's right, but it has worked for me good so far
Old 07-09-2005, 09:13 PM
LS1FIRE's Avatar
The reason why is i just purchased a craftsman tq wrench and the lowest setting it will go is 25ft.lbs to 250ftlbs.
Old 07-09-2005, 09:18 PM
bigdsz's Avatar
FWIW many torque wrenches are inaccurate at the low and high end of their ranges.
Old 07-09-2005, 10:02 PM
yea i was very worried... i used my dads old crastman tq wrench.. not bad shape.. still appared to be fine but it was like 20 years old lmao.. 10-150lbs well i got it to 22, and then when id check it it would be different or off.. i was using a extension tho.. small 1 inch one.. maybe that hurt it.. so i just put htem at 23-25 made sure none of htem were way loose, and just recently pulled the vavlecovers and made sure none of htem had backed out or like started coming apart or some ****.. they were fine, so i guessed right i hope
