PRC Update --> 1QuickT-A Cylinder Head Offer!!!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Lets keep this post positive guys I'm not trying to start sheeeet in here, I just want a opportunity to defend my product fairly.
We have had procedures in place now that insure cylinder heads meet certain flow & clearances specs before they are shipped out the door. It's only fair that if we're going to compare cylinder heads that we compare whats available now. Am I wrong??
Jason
2005 Twin Turbo C6
I'm not trying to post information that is incorrect, I just want a accurate discusion.
Jason
2005 Twin Turbo C6
Thanks Jason... I'll definately do that. I was refering to the bowl thing. It's good to see your on it Jay. What is it like 12:30 am there??
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
However, with that being said.. I'm just posting to say thank you for backing up your product, and that I would like to see results. I have been using PRC valvesprings, and perhaps one day for my gto prc heads might not be out of the question.. it'd be good to see how it stacks up.
Peace,
Josh
i have wondered why a shop/company hasn't done this before, not because of some bickering crap, but to demonstrate their product against the competition.
direct comparison is good...
Jason two fold on the stepping up part. I remember another shop, PP, that churned out cyl heads, under supervision of the same guy thats "hand finishing" your current PRC's, and their customer service was top notch, eventually the beast reared its ugly head and the quality or lack of was apparent. Now, fast forward, and I can only hope that this same bullshit doesnt happen here. Understand its not easy to bring this up, but TSP used to support PP as much as Gomer. Then it all stopped. Talking with Terry it was not him, it was the actual owner that wouldnt make the changes, so he left, you stopped carrying his product, and Terry is still finishing heads, which are brought on here to be suspect. You make changes to the QC, so did PP! Scary the irony of business and life, and how the circle we run with talks stories about our character.
*This is not meant to be bashing. Seriously, it is irony at its worst.*
Charlie
This isn't really irony at all, just a example of not having your story right. Terry only recently started finishing the cylinder heads. I have the upmost of confidence in what Terry does. If Terry had done the cylinder heads that we are discussing then I would agree, but he did not. The finish work was moved to Racetech because Terry is so talented at getting heads to flow.
I also disagree about decking the AFR's to match compression. Aren't we comparing out of the box to out of the box? I think the bigger compression is definately a plus, kind of like afr's smaller runner is a plus.
Jason
2005 Twin Turbo C6
If I felt Terry @ Racetech wasn't the best person to be finsihing the heads then we would go a different route. Even Terry would agree that if there was a better method for finishing them then we would do it.
I think alot of time Terry gets a bad rap because he came from Patriot. Keep in mind the quality issues did not leave when Terry left PP. I think both Terry & Patriot made some definate mistakes back in the day or they probably would have taken over the market & everyone (including us) would be running their products. That did not happen for whatever reasons that doesn't need to be discussed in this thread. As a result there is still alot of cylinder head competition out there & the customers are the ones that benefit from it. We started developing because we thought we could make the best cylinder head available. IMHO that's what we're doing now
Give us a chance to fix this ONE set of cylinder heads before you compare this situation to a situation where cylinder head issues were ALOT more common. Jason
2005 Twin Turbo C6
To keep up with cylinder head demand we are curently interviewing several School of Automotive Machinist graduates to select someone to finish cylinder heads in house. By finishing heads here & at Racetech we can offer a wider selection of products & increase our cylinder head producing capacity
Keep in mind Terry will help train the new machinist so we make sure the heads are finished to perfection! There will be no training people off the street to finish cylinder heads, we know how important this step of the cylinder heads proccess is & as a result we will only employee the best. Alot of companies don't include a flow sheet, or provide flow sheets for a similar head. We now package a flow sheet specific to each cylinder head for all of our customers! Like I said before if someone isn't 100% happy with their PRC purchase then we're not happy. Jason
2005 Twin Turbo C6
After you pick up the heads and have seen them flowed on racetech's bench, we will more than happy for you to swing by here, and you can witness the test on our Superflow 1020. This will assure both companies and the members of this forum, that impartial flow data for the heads used in this test has been gathered. More than likely you will drive right by us on the way to pick up your heads. Guess you could say we are located in the "DMZ" for this particular battle.
I am waiting eagerly for these results
