Woooooooot, cam is in!
Old Aug 10, 2005 | 12:53 AM
  #61
CaptUSA's Avatar
Don't keep us all waiting.
Old Aug 10, 2005 | 05:59 AM
  #62
eallanboggs's Avatar
Your SES is going to be P03XX DTC. It could be anything from 300 to 308. If it is 301 to 308 the LSD is the cylinder number that is being detected as having the misfires. If it is P0300 the PCM can't quite figure out exactly which cylinder to blame so it just says someone is misfiring, but I'm not exactly sure who it is so I'll spread the blame across all 8 cylinders. Over time you will find that your PCM will relearn this new camshaft and gradually become less sensitive to the rough idle. You may find that the SES will come ON more frequently on cold mornings, but eventually the PCM will desensitize itself and the SES will no longer come ON. This won't happen overnite, but one day you'll say to yourself: Damn I havn't seen that SES in a long time now.
Old Aug 13, 2005 | 09:15 AM
  #63
noah89's Avatar
Manny,
Have you had your dyno pull yet. I'm interested in your numbers as I'm looking at the TR224. Thanks.
Old Aug 13, 2005 | 02:47 PM
  #64
Reject's Avatar
wow lot of reading!! i'm interested in this now too!!
Old Aug 14, 2005 | 09:12 AM
  #65
MannyZ28's Avatar
Yes yes.....it got postponed again!!!
I can't believe you are still keeping track dude!
Ok....I made a new appointement, it's gonna be this Thursday, August 18th at 10 AM!!
The hold up is basically that we had a bit of a crisis at work, so I couldn't get a day off, and besides that, my buddy still has a bit of fiddling to do on the car.
We want to take the valve covers off again and check the torque or the rocker arm bolts. Also, my Spohn Torque Arm still needs some work, we need to tighten to front bolts down some more, and I ordered some longer bolts for where the TA attaches to the rear end...the stock bolts without washers are just cutting it to close.
Lastly, we wanna do the restrictor mod properly so that the holes are 3/16" not 5/16" as they are now.
Anything else I should check?
I have driven the car as little as possible, coz it's obviously running rich, so I hope my new plugs didn't get too messed up by this. I guess we'll pull one of the easy ones have have a good look at it.
I promise I'll post results on Thursday!!
Manny
Old Aug 14, 2005 | 09:15 AM
  #66
MannyZ28's Avatar
Yeah, I was at Hooters the other night, and one of my buddies happened to be there and he had a reader with him. It was the P0300...multiple misfires, two instances of it. It comes on and off, but I am sure the tune will take care of that, right?
Manny
Old Aug 14, 2005 | 09:56 AM
  #67
02WS6Bird's Avatar
Manny
Yupp the tune should take good care of it
Old Aug 14, 2005 | 11:15 AM
  #68
ArcticZ28's Avatar
Manny
I ran my iron block 375 w/ a 244/248 cam on the stock tune for about 250 miles before I got it tuned and the plugs are fine. You shouldn't have a problem.
Old Aug 14, 2005 | 01:20 PM
  #69
Reject's Avatar
lol got a fan club goin on here!
Old Aug 14, 2005 | 06:55 PM
  #70
MannyZ28's Avatar
I know it,....I feel famous!!
ArcticZ28,
My car is not running on a stock tune right now, it's running on a tune that was done after the LS6 intake and the headers were put in, and while it was there, the Throttle Body was ported. So I really dunno how it's running, but it sure smells rich...hehe. Not to the extend of gas dripping out of the exhaust or anything. It doesn't hesitate at all, doesn't backfire...it behaves rather well once she's warmed up
Manny
Old Aug 15, 2005 | 12:42 PM
  #71
ArcticZ28's Avatar
ArcticZ28,
Manny
So you should be even better off with a tune that's geared more towards your aftermarket mods than the stock tune. I was just trying to show you how I ran my radically different motor for a long time on the stock tune and was fine. And the exhaust didn't just smell rich, it blew black carbon out the exhaust if you revved it
Old Aug 15, 2005 | 02:30 PM
  #72
MannyZ28's Avatar
I am not sure, but I don't think mine does that......double as a black smoke fog machine.
I can't wait to get this tuning business done, I'll feel much better afterwards.....at least I hope I will.
Manny
Old Aug 18, 2005 | 02:28 PM
  #73
noah89's Avatar
Manny must be out cruising. Hope to see the dyno numbers tonight.
Old Aug 18, 2005 | 02:57 PM
  #74
JoeyAnderson's Avatar
**** that shop. Waiting that long is rediculous.
Old Aug 18, 2005 | 03:06 PM
  #75
MannyZ28's Avatar
374hp and 365 tq....check the other post I made in this forum.
Manny
Old Aug 18, 2005 | 03:09 PM
  #76
ArcticZ28's Avatar
30hp and 13 tq... pretty good numbers considering the basic bolt on's, should be able to squeeze a bit more torque out of that especially with the 112 LSA.
Old Aug 18, 2005 | 03:22 PM
  #77
MannyZ28's Avatar
My car has never been a torque monster.....I am failry happy with the numbers....I am sure if I re-dyno in the winter time when it's not so obscenely hot, car will do better
Old Aug 18, 2005 | 03:31 PM
  #78
ta_silver_bullet's Avatar
yeah those numbers are good i made 375rwhp 372rwtq with a similar cam 224 .581 lsa114 with an auto with a 3000 stall
Old Aug 18, 2005 | 04:11 PM
  #79
MannyZ28's Avatar
Considering your car is a auto with a stall, your numbers are quite a bit better. I am gonna attribute it to shitty dyno weather. 100 degrees intake temp just didn't help it much.
Manny
Old Aug 18, 2005 | 09:35 PM
  #80
ArcticZ28's Avatar
Manny
Well then your only choice is to spray it now
