View Poll Results: AFR or TEA
Spend the extra money on the better head
97
68.31%
Save a bit of money and put it toward another mod or tuning
45
31.69%
Voters: 142. You may not vote on this poll
AFR vs TEA
Old Aug 7, 2005 | 12:06 PM
  #121
DrkPhx's Avatar
Originally Posted by 99ssleeper
I still get 11.07:1 with 60cc chambers and .060" gaskets....
Cyl vol= 43.2595 cid
Chamber vol= 3.661425 cid
Clearance vol (piston out)= -.0835356 cid
.060 Head Gasket Vol= .7160194 cid
So,
Swept vol= 43.2595 + 3.661425 - .0835356 + .7160194 = 47.553409 cid
Unswept vol= 3.661425 - .0835356 + .7160194 = 4.293909 cid
Swept/Unswept= 11.07..............11.07:1 SCR
Anyone back me up on this?
Have you tried the rbracing-rsr.com calculator mentioned above to back up your calculations?
Using: 3.898/3.622 stroke/bore, .060 head gasket, -.008 deck height, 0.00 for piston top, and 60cc combustion chamber it indicates a 11.09 static compression. Not far off from your numbers. Did you measure the deck height?
BTW - Do you still need the tools? Let me know, I'm heading to Sean's right now.
Old Aug 7, 2005 | 12:11 PM
  #122
PREDATOR-Z's Avatar
Beast, believe me I like your calculations better.
For me it would be 10.6 VS 10.97
Old Aug 7, 2005 | 12:14 PM
  #123
Beast96Z's Avatar
I understand. I used to use the same calculator you did until I found out you couldn't enter the correct piston height. Then I was on a mission to find one that would let you enter the correct number. That's when I came across this one. It's deffinatlly the correct one.
Old Aug 7, 2005 | 12:28 PM
  #124
JZ'sTA's Avatar
Gonna change my post as the last one didn't make since and was hard to read.
Using the -.007 number why is it that a stock LS1 will now read 10.19 compression?
I used 3.898 bore
3.622 stroke
.060 head gasket
-.007 piston
0 for the flat top piston
66.67cc for the heads which from what I have read is a stock LS1 head.
It shoes 10.19
Now if GM made the LS1 a 10:1 motor and all my figures are correct then things dont add up.
With a compressed .054 gasket you get 10.33
Using the .060 gasket and 66.67 head a .001 piston deck would give you 10.01 compression.
Using a .054 gasket and 66.67 head you would need a .007 piston deck.
These numbers add up better according to all the other numbers we have.
What is correct?
Old Aug 7, 2005 | 12:37 PM
  #125
Beast96Z's Avatar
Damn, I'm glad I posted it then. I didn't know this many people were having trouble finding a correct one.
Old Aug 7, 2005 | 12:40 PM
  #126
JZ'sTA's Avatar
Yeah for sure Beast.
With the new calulator I started running numbers and am confused again. Check out my edited post above your last one and voice why you believe things dont add up.
Old Aug 7, 2005 | 12:45 PM
  #127
PREDATOR-Z's Avatar
LOL, this is funny.
On a stock LS1, I've read 10.0:1 and 10.2:1 in different articles and magazines.
BTW, how can you physically measure SCR again?
  #128
JZ'sTA's Avatar
Now it gets even more confusing.
From what I am seeing maybe the cc's of the heads are incorrect.
Ran some more numbers based on the LS6 10.5:1 compression.
3.898 bore
3.622 stroke
.054 head gasket
-.007 piston
0 for flat tops
64.45 which again is what is "said" to be a stock LS6 head
Compression equals 10.46 which is very close.
With the .054 gasket you get 10.61, which I can still live with.
With a .007 instead of the -.007 you get 10.13 with the .060 gasket and 10.27 with the .054 gasket.
This just messes everything up now.
With the 10:1 compression LS1 the calc looks better at +.007 with the 10.5:1 LS6 the calc looks right at -.007.
That leads me to the heads being incorrect.
Old Aug 7, 2005 | 12:51 PM
  #129
JZ'sTA's Avatar
LOL, this is funny.
Well if 10.2 is the answer then we have a winner.
66.67cc's and -.007 with a .060 gasket equals 10.19:1
That means GM is too damn dumb to know what compression the LS1 motor is, or I am to damn dumb to find the facts.
Now if the LS1 is really a 10.1 then the head would have to be a 68 cc chamber using a .060 gasket and a 69.5 using a .054 gasket.
Old Aug 7, 2005 | 01:03 PM
  #130
JZ'sTA's Avatar
Speaking on cc's of heads and compression are we all on the same page when it comes to milling?
Every .006 milled equals 1cc?
I have also seen every .007 used.
What is the agreement here?
Old Aug 7, 2005 | 01:15 PM
  #131
Beast96Z's Avatar
I'm not trying to sound like a know it all here, but the negative number is fact not fiction. It isn't anything that can be questioned. If the piston sticks up past the deck, it is now at negative height. This is the way it has always been. There aren't that many motors out there were the pistons comes out of the hole. This is why most calculators measure in the hole. As for the stock numbers, you have to remeber you are dealing with a mass produced casting. cc's on each head will vary. I've seen up to 3cc's diffrence on diffrent heads that were untouched factory castings. I understand what you are saying about GM's calculations. I think they throw out an average number to the consumer, but it really will vary from car to car. You can also consider this: On the cars that came with the .054 gasket, what's diffrent between them and the cars that came with the .064 gaskets? Nothing, other than the gasket, but yet there was no change in compression according to GM. Makes you wonder.... Oh, since when have the MLS gaskets gone down to .o60? I thought they were rated at .o64"?
Old Aug 7, 2005 | 01:21 PM
  #132
jrp's Avatar
jrp
SN95 Director
guys, when it comes down to it just measure your own **** and then use the calculator too figure out the compression. with GM's tolerances no two motors are exactly the same, i've seen deck heights vary from .002 to .010 out the hole, head volumes from 66 to 68, ect.
Old Aug 7, 2005 | 01:30 PM
  #133
JZ'sTA's Avatar
I agree 100% Beast.
I have always guessed at the number and this just makes it easy to guess more accurately.
I know not every setup is the same from GM but thought it would be fun to throw some different numbers out there.
Not instead of guessing .3 -.4 more compression then what Ross says I can acturally guess on the "avarage" head cc and -.007 "avarage".
My old guess on my motor was 12.23 and now I see it is 12.36. Guess my guessing wasn't that bad.
Anyways at least were not discussing the "TEA vs AFR" same old **** anymore.
Thanks for the link. It is a favorite now and I trashed the ross compression calculator.
Old Aug 7, 2005 | 01:55 PM
  #134
99ssleeper's Avatar
No, I calculated this using formulas from Thermo class at school. I assumed .007 deck height, add the carbon it's probably more like .017, lol.
Yeah, I could use those tools if you dont mind. I can pick them up sometime this or next week (I work in Eden Prairie...cant be that far from ya)...
Thanks Gino
Old Aug 7, 2005 | 02:00 PM
  #135
99ssleeper's Avatar
.064 would be better for me. I used .060 since that is what SDPC says it is...
Old Aug 7, 2005 | 03:33 PM
  #136
JakeFusion's Avatar
Super Hulk Smash
At least this is a technical thread now.
Why would Deck Height be negative? It's not volume you are measuring, because that's another formula. Deck Height is simply the space or distance between the piston and the combustion chamber at top dead center (TDC).
The calculation you plug into my earlier reference is: Clearance volume = 0.7853982 x bore^2 x deck height
I can see why you assume that if a piston protrudes past the block than it must cut into the volume of the clearance, but you aren't concerned with that for SCR. At least not in any formulas I know. You only need to worry about the actual volume between the piston and combustion chamber.
Old Aug 7, 2005 | 03:55 PM
  #137
99ssleeper's Avatar
Yes you do have to worry about it because that measurement needs to be subtracted from the combustion chamber + head gasket volume.
If it was zero deck height, then it wouldnt be an issue. When the deck height is positive, that gets added to the combustion chamber and head gasket volume because the Unswept volume is larger.
Trust me...it has to be factored in.
Edit: .78whatever is the volume. It is the protrusion amount (.007) times bore^2 divided by 4.
Old Aug 7, 2005 | 04:00 PM
  #138
99ssleeper's Avatar
Area = pi times radius^2 ...or.... pi times diameter^2 divided by 4.
To get the volume, multiply by the .007" and you have the clearence volume/deck height volume.
Old Aug 7, 2005 | 04:05 PM
  #139
JakeFusion's Avatar
Super Hulk Smash
I get 0.644417508 for clearance volume. Once again for Compression Ratio it is Cylinder vol. + clearance vol. + piston Comp. vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
And the clearance volume forumla is 0.7853982 x bore2 x deck height
I'm not going to write a proof, but if the piston actually protrudes .007" then sure your formula works, but you are measuring the distance from chamber to piston when you enter that value in my formula or on any of these online calculators. I have no idea how far the piston is actually out of the hole, nor is it necessary for my forumla. I am assuming that when someone says that the LS1 has a deck height of .006-.008 it has nothing to do with the actual protrustion and recession of a piston. Perhaps that is why these forumlas are not spot on. But I know that my forumla looks for deck height, not piston out of the hole.
Thus, I don't care if the piston is down in the cylinder .5" or if it sticks out .006, it will still be a positive number in my formula, because my value is that distance from the combustion chamber to the piston. It will just be a larger number if the piston is recessed.
Old Aug 7, 2005 | 04:11 PM
  #140
99ssleeper's Avatar
either way i guess.
i use the deck of the block as the zero point between swept and unswept measurements....
