largest bore on iron block w/ stock crank
Will be running boosted (15plus psi) and wanting to know the largest bore one can take the 6L iron without weakening it? BTW, the plan is to use a stock crank.
Thanks guys.. the motors being rebuilt due to an excessive oil consumption issue so I figured what the hell.. As it is, I'm not gonna be able to run all it's capable of anyways, so I'll just have them clean it up and leave it as is..
Just couldn't stop listening to that evil voice in me saying mod.. mod.. mod.. or more.. more.. more..
Hey Rick: That load dyno is bad ***!!! Thanks for letting me sit in a bit on that tune session. I'll see you in 3 wks..
Arnel
Arnel
Originally Posted by bluecamaroz28
How much would the stock 3.622 crank handle?
Will forged low comp pistons and forged rods swap, only, be enough to run high boost (16psi or higher). Or, should a forged crank be used.
if you do a search on stock crank limits or somthing to that matter. there are a few people on here that have upwards of 800rwhp with the stock crank. you should be good. only one way to find out for sure.
