G5X4 Cam, which Head AFR 205 or AFR 225, or TEA 2.5
hey whats up guys, i dont really know much internally about the LS1 , but i want to buy the G5X4 cam for my stock cubed 346ci. i want to do Heads alond with finishing off my bolt ons at the same time. 4 questions though, which Head do u recomend that works great with the g5x4 cam, Where can i get the G5X4 (I checked LGMOTORSPORTS.COM) but they dont have the g5x4. and last but not least what kinda power can i expect, AND Times with a 12 bolt, 4.10s, slicks and a good driver
Thanks
Thanks
Give Lou a call over at LGMotorsports and he'll give you the rundown. That cam is kind of risky without flycutting your pistons. A missed shift could be devastating with that cam choice. To be safe, I would recommend the G5X2 because it is a bit safer on the clearance, and it makes awesome power.
As far as heads go, read the post AFR vs TEA below. There is input from both sponsors.
To make the kind of power you want I would go with the TEA 2.5. Right now you cant get the AFR 225 in the small chamber. With a stock bore you would need to mill alot to get the 11:1 compression ratio. The 205 is a great head, but shown that the BIG cams dont yield alot more power than the small cams due to the limited higher lift flow. To be realistic you cant go wrong with either. IMO would be the TEA.
Brandon
Brandon
LS1 Tech Administrator
Brandon
Brandon
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Originally Posted by Patrick G
Only partially true. Small cams make BIG power with AFR 205 heads. That part is true. But what is also true is that big cams make even BIGGER power with the 205s. LG has made 530-540 rwhp with AFR 205s with one of his bigger G5-X cams. I made 433 rwhp with AFR 205s and a 215 cam. Stay tuned to see what kind of power I make with a 231/234 cam and the same 205 heads.
First you are the stall swap king, now you are rivaling Gomer for the cam swap title???
Flycuting will be a must.
Both heads will get you some very nice gains.
Price is very simialr as well when you add in the TEA LS6 core charge. I would try and get into a 64cc head and a .040 gasket for 11:1+ compression if you plan on making some big power.
If this were my own car I would do a 59cc head with a .040 gasket and pick between TEA and AFR.
That would net you 11.8:1 and make some serious power.
Budget is the key.
If you have 2300 bucks to spend on heads do the AFR's in not then spend 1700 on a set of the 5.3's from TEA upgraded to stage 2.5's.
It's only a 600 dollar difference which is huge to some and very little to others.
Budget is the key.
SN95 Director
Originally Posted by stang killer
The way I see it is if you go with the LG cam, you should get the LG AFR heads also. That combo has put down awesome numbers on C5's
