T&D rockers and pushrods rubbing?
Old Jan 14, 2003 | 05:38 AM
Plan B's Avatar
Default T&D rockers and pushrods rubbing?
I'm wondering if anyone has had this problem?
Pic here.
I have set the stand height correctly, and was just about to dummy up and check P-V clearance and found this.
I put the stock rocker in place and it's perfect! Any help would be greatly appreciated.
Peter.
Old Jan 14, 2003 | 07:13 AM
1 Stout Z's Avatar
Default Re: T&D rockers and pushrods rubbing?
Don't have any experience with them but looks like you might have to break out the dremel and do some clearancing to the rail.
Old Jan 14, 2003 | 09:04 AM
Paul F's Avatar
That is very common. You'll have to open up the pushrod holes and clearence the valvecover rails to use the T&D Rockers. Hope this helps...
Old Jan 14, 2003 | 10:51 AM
Ryan K's Avatar
Pathological Modifier
The ARE heads that I have have been massaged in that area to provide the needed clearance. I'll snap a picture for you.
<img src="http://www.teamnwracing.com/images/parts/tdclearance.jpg" alt=" - " />
<img src="http://www.teamnwracing.com/images/parts/tdclearance1.jpg" alt=" - " />
Ryan K.
Old Jan 14, 2003 | 11:18 AM
Plan B's Avatar
Great! Thanks guy's.
Ryan, Thanks for the pic's. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Peter.
Old Jan 14, 2003 | 11:56 PM
HOWQUICK's Avatar
Check your rocker geometry...stand height by the checking gauge isn't everything.
Longer p/rod maybe required. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 15, 2003 | 05:53 AM
Plan B's Avatar
After using the supplied GUAGE, I then blued the top of the valve stem and with the rocker in place, moved the valve from the seat through to the 600 lift range that I require (several times). The mark left on the tip of the valve stem is exactly in the middle. I'm happy with that. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The pic shown at the top of this thread is with the rocker adjuster screw all the way out... I still wouldn't/couldn't torque them down at this point. (Hense the push rod is too long already) I borrowed an adjustable push rod and shortening to where I'd like to have the field of adjustment (according to the instructions) didn't help.
Last night, I spoke with one of the sponsors here, who is currently supplying me a set of LS6 heads for my 422. He said the same as the guy's above.
I'm only a dumb plumber, but with what the guy's above have suggested, it sure makes a lot of sense to me and I appreciate it.
Surely this slight modification wouldn't change the performance of the heads. Cheap insurance anyway. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jan 15, 2003 | 11:44 AM
jmX's Avatar
jmX
Bust out the dremmel and elongate those pushrod holes. Visceral I think was the first person on ls1tech to have this problem and it was about a year and a half ago. I enjoyed seeing him drill out metal from his nice brand new $4000 LS6 stage 3 heads. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 15, 2003 | 06:51 PM
HOWQUICK's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Plan B:
<strong> Check your rocker geometry.
Surely this slight modification wouldn't change the performance of the heads. Cheap insurance anyway. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">it was only a suggestion...worked for me-10k km without issues. As you say, relieving them won't hurt.
Good luck with the LS6 heads...thought you would of gone C5R <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Plan B's Avatar
Thanks jmX. All done now.
