new locks for dual valve springs?
Old 08-14-2005, 08:35 PM
LS1powerhouse02's Avatar
Default new locks for dual valve springs?
i'm about to install a set of comp cams dual valve springs with a comp cam 230 duration and .591 lift. I'm just wondering if i need to order new locks. I have new retainers and spring seats. If i do need new locks then what kind? Oh by the way i have a 2002 Z28 and the locks are stock
Old 08-14-2005, 09:47 PM
blkZ28spt's Avatar
Just reuse the stock locks. It's a good idea to buy one or two spares from a dealership for if (when) you lose one.
Old 08-15-2005, 03:41 AM
eallanboggs's Avatar
It's a good idea to spread some shop rags around the heads during the remove/install process as the locks are easy to drop and hard to find once they do.
Old 08-15-2005, 04:56 AM
Demon SS's Avatar
while the locks are re-useable, I personally would suggest buying new ones from GM or where ever, a new set cost like $25.00. why spend hundreds of dollars on a cam swap and then skimp on a few dollars by using old locks? most of (if not all of) the Comp Cams retainers are setup for the stock style locks.
Old 08-15-2005, 09:43 AM
blkZ28spt's Avatar
Because the stock locks are perfectly fine. What benefit would you get from new locks?
Old 08-15-2005, 02:54 PM
Demon SS's Avatar
the benefit is that they are new and have zero wear and tear, valve locks do wear. the guy was just asking for opinions, I stated mine. I know lots of folks who re-use locks and are running strong. it just make sense to me to use new ones, but that is just my opinion.
Old 08-15-2005, 03:04 PM
blkZ28spt's Avatar
I can understand that, but I wouldn't quite call using the old locks "skimping". It's just another one of those things that comes down to the individual person. For example, I run dual springs with stock lifters and I know others that wouldn't do that (but most do, anyway). Not to mention the debates that can come up regarding oil pumps and timing chains.
Old 08-17-2005, 10:52 PM
thanx for the input guys!!
Old 08-17-2005, 11:03 PM
jz06man's Avatar
Get new locks, it's very cheap insurance, or not... You asked.
Good luck
