Taking the piston off the connecting rod
Does this require a special tool?
stock rods are press fit, not floating.....you have to press the pins out........
toss both in the garbage and go get some good rods/pistons......
Can i re use the pin? If no, whats the part number for what ill be needing to get the piston back onto the new rod
so wait.....you have the engine apart anyways?
if so, toss the rods and pistons in the trash and get a set of forged rods and pistons.........yes the pistons and rings will run you about $700-$1000 but you will never brake them and will have a MUCH better sealing/running engine....
for rods, eagle makes a forged rod with floating pins for ~$500 and will take upwards of 800+ rwhp.......
If you are not doing anything crazy like high boost FI, nitrous and contstant revs above 7k, stick with the stock rods, they are underrated imho and the pins can be reused. Just replace the rod bolts with katechs or ARPs. Get a set of Mahle Piston packs from one of the sponors here for around $500.
though I agree with everyone that says if you have it apart anyway you should go forged.
Give the guys at Callies a call, they can set you up with a nice package.
I'm exchanging only 1 rod because the motor spun a rod bearing and needed to get the crank machined and replace one of the rods. So, thats where i stand. I think he should be fine with the stock pistons. He wont be going to wild with this setup.
Whe reinstalling the pistons the dots that are ontop of the pistons all face forward towards the front of the motor, correct?
Also, all the pistons got mixed up. Is there a certain order the pistons get installed in. There is no numbers on any of the pistons and it looks like they should be installed a certain way. Or can they just be put in one at a time with the dot facing forward?
(I would think) they should face to the "left" (if looking at the "bank" from the side).....
you could always look at the "valve notches" (if you ever floated a valve) in them......
Just took the pistons out in order... And someone decided to throw them in one stack.. (Save space
I didnt check which way the dot ontop of the piston was facin when i removed them,but i think i remember they all facing forward towards the front of the motor. All the stock pistons that are in the motor had a dot ontop of the piston.. I just want to make sure they go in the correct way..
So im guessing all the pistons should go in with the dots facing forward towards the front of the motor. Or does it even matter on stock 02 pistons?
