Timing cover issue with dual Rollmaster
I have the engine out and on the engine stand, so getting to everything is easy.
I installed a Rollmaster dual timing chain and SLP LS6 oil pump. I used the shims as directed by Rollmaster. My problem is the timing chain cover. It sticks out too far and will not bolt up. I also understand that there is to be 22 thousands of and inch of clearance between the oil pump and the front cover. Anyone have any idea what I am doing wrong?
The motor is out of an 02 Camaro.
Also, since the motor is out, do you guys reccomend changing the rod bolts to ARP?
Hope that helps.
Bryan
Bryan
Speed shop called SLP and they said to NOT use the spacers that come with the Rollmaster dual chain. Their pump clears the chain. You can see on the back of the pump where they removed some material. Also, once I torqued the ATI dampner down, it pulled the gear back a little more and made for a bit more clearance.
No grinding required. Thanks for all the input. Zach
i cant stand buying stuff.... usually with lil or no directions.
half the time its common knowledge, or you have done it before and know.
thanks slp.
