your rpm rev limits ?
Old Aug 26, 2005 | 06:45 AM
cowboysfan's Avatar
Default your rpm rev limits ?
just wondering upto what rpm will a stock bottom ls1 handle? plus after your mods or if stock with no mods what rpm limit do you guys have on your ls1 set too?
furzaws6
Old Aug 26, 2005 | 06:54 AM
mikemodano9c's Avatar
a lot of people spin the stock to about 6800 max with larger cams. some replace rod bolts and go to 7000. some think that is crazy and stay at 6500...
my limiter is set at 6800 and shifts at 6700...
a stock internal car probably won't benefit much from raising the rev limiter, but it could help your shift extension...
most consider 6500 safe, 6800 pushing it, 7000 asking for trouble, 7000+ here she blows...lol
Old Aug 26, 2005 | 09:15 AM
pewter 01 SS's Avatar
i think that it will handle up to 7k but who knows how many times.. you should shift around 6700 just like mike said dont try to go up to high because little problems will happen..
Old Aug 26, 2005 | 09:28 AM
ExceSSive's Avatar
My A4 shifting at 6500 scares the crap out of me.
Old Aug 26, 2005 | 10:16 AM
GuitsBoy's Avatar
I have a 6800 revlimit, and a 6400 shift light. I rarely take it up there, although i have banged the revlimiter twice on botched shifts.
Old Aug 26, 2005 | 01:19 PM
freakynipples69's Avatar
Well I THOUGHT stock bottom end could easily handle a 6800 redline, with my shift point at 6400........nope, guess it couldn't.
Old Aug 26, 2005 | 01:27 PM
rollinna65's Avatar
mine's set at 6800 and i try to shift at 6600.
Old Aug 26, 2005 | 01:32 PM
Ryan02SS's Avatar
6800rpm redline w shifting for max power at 6450rpms. My engine has seen 6500rpms since I installed my LS6 cam w 4K miles on the engine.
freaky, Wasn't your car down a few qts on oil when you spun the rod bearing?
Old Aug 26, 2005 | 01:35 PM
Kraest's Avatar
Mine's set at 6900 rpm.
Old Aug 26, 2005 | 02:16 PM
jmm98LS1's Avatar
I've got mine at 6800 redline, shifts at 6400.
Old Aug 26, 2005 | 03:10 PM
GuitsBoy's Avatar
I though freaky posted that it wasnt a problem with oil. What else spins bearings though? I could understand if it threw a rod...
Old Aug 26, 2005 | 03:32 PM
99 Pewter TA's Avatar
I got mine set at 6550. I shift at 6200-6300
Old Aug 26, 2005 | 05:43 PM
Cstick's Avatar
Rev limiter at 6500. I have shifted at 6000 to 6400 at the track and can not tell a difference. My HP curve flatens out at about 6 to 6500. So the shift light gets set between 6 and 6200. I do not see how it would help me to shift any higher. I shift early and drop back a little higher on my torque curve.
Old Aug 26, 2005 | 06:02 PM
fast98's Avatar
6800 shift at 6600. 98 block with 115k, has the last 10k on it this way.one day i will get lucky and have an excuse to build a 383
Old Aug 26, 2005 | 08:13 PM
nostyta's Avatar
Rev limiter set at 6800, shift between 6400 and 6600.
Old Aug 26, 2005 | 08:26 PM
BOONE's Avatar
My limiter is at 7200 and my shift light is at 6800, and I've done this with 3 ls1s in a row. I set my shift pill at 7000 when i race, 6800 day to day playing. Ive never blown or spun anything, but once i overreved and bent exhaust valves. Just my experience, but if i had the torque of a turbo id probably shift at 6500 or so. If i did blow it up id just go further on the next build, got some ideas ya know.
Old Aug 26, 2005 | 10:04 PM
ls1 joe's Avatar
7700 rev limit shift at 7400
Old Aug 27, 2005 | 01:09 AM
BriancWS6's Avatar
With my pewter car and the TSP225 I had the limiter set at 6800 and the car shifted at 6500, A4 BTW. I had a lot of pulls with that car so I'm pretty confident with that rev limit. I am hoping that the cam I go with in the black car won't peak too high so I can use the same rev limit for it as well.
Old Aug 27, 2005 | 09:20 AM
low oil had nothing to do with the spun bearing. I thought it did but when I opened up the engine, I could tell that there was deffitinly enough oil, and that oil starvation wasn't the problem.
Old Aug 27, 2005 | 11:39 AM
DONAIMIAN's Avatar
Limit at 6800 shift at 6500. When the new cam goes in, shifting at 6800 rev limit at 7100.
