Engine Bearing Explanation Needed...
I have been looking at engine bearings and am wondering which ones I want. I am putting together a rotating assembly which will use an Eagle 4" crank and probably Eagle rods. The main and rod bearings I'm seeing from Federal Mogul have like +1, +10, +1X, +9, and standard chamfer? First off, what does this mean? Secondly, how do I know which one is wanted, or does it matter? Also, are Federal Mogul cam bearings any good? Thanks for the help!
the number probably is an undersize or oversize bearing - in case you get your crank turned or your rods resized and need a different bearing (larger or smaller) to go with them.
8 Sec Tuner
The 9's and 10's are used to provide less/more clearance when using a journal that has been turned .010.
If you're using new parts you will end up using STD's, 1's, and X's to achieve the main/rod bearing clearance that you want.
So is this a hit and miss situation? Should I just get standards and hope for the best?
I meant that I was buying the bearings also. So I guess I won't buy the bearings then. Thanks.
So complete rolling assemblies are already clearenced and come with the correct bearings?
