After replacing valve seals....
Old Sep 3, 2005 | 06:12 PM
CCut's Avatar
Default After replacing valve seals....
Finished replacing the valve seals and I fired the car up, she was fine til she was warmed up, then it started making this squeeling noise and I cant really pinpoint where its coming from. Any ideas???
Old Sep 4, 2005 | 12:20 AM
glennhl's Avatar
Look for a small child hidden under the hood, they'll squeal when it gets too hot. Seriously, check the serpentine belt. If you got it wet at all with dexcool, that darn thing will squeal for days. If you need a new belt, get one. If not, just wait and it may go away. Also check your idler pulley, they will squeal if they are failing.
Old Sep 4, 2005 | 12:07 PM
CCut's Avatar
Ok, I replaced the belt and the idler pulley and its STILL squealing.
Old Sep 4, 2005 | 01:42 PM
glennhl's Avatar
The squeal could be the alternator or any of the accessories. I just gave you the two most common reasons for squeal.
Old Sep 4, 2005 | 02:40 PM
CCut's Avatar
I took the belt off, fired the car up and it was squealing.
Old Sep 4, 2005 | 02:44 PM
ATVracr's Avatar
is it RPM based? ie:
change sound or get louder with more RPM?
Old Sep 4, 2005 | 02:47 PM
CCut's Avatar
Sound of it pretty much stays the same.
Old Sep 4, 2005 | 05:39 PM
T-maxx's Avatar
Just a thought here. Maybe you didn't seat them corrrectly. There should only be about 1/8-1/16 of an inch clearance. Thats most likely not the prob. Did you check the A/C belt too???? Check the washers on the accesories. Did you spill some coolant?
Old Sep 4, 2005 | 06:41 PM
CCut's Avatar
Check this out, had the car running and my neighbor unscrewed the oil cap some and it started sucking in air and the noise went completely away, tighten the cap back up and the noise came right back. thoughts??
Old Sep 4, 2005 | 08:45 PM
SPEEDYws6's Avatar
Sounds like a restriction in the PCV system, check the valve and hoses.
Old Sep 4, 2005 | 08:56 PM
MiaSSmaro98's Avatar
wow these are the things that drive someone crazy
Old Sep 4, 2005 | 09:00 PM
CCut's Avatar
They sure are!
SPEEDY: i'll check the hoses and valve tomorrow. thanks for the insight
Old Sep 4, 2005 | 09:23 PM
co.6z28's Avatar
damn cut, hope you get it figured out
Old Sep 5, 2005 | 12:51 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
That is the crankcase not having a fresh air source and your PCV pulling a vacuum on it. Make sure your breather hose on the valve cover closest the the oil cap is unrestricted. This is the hose from the valve cover to the throttle body. I seen a guy plug off everything other than the PCV valve hoses itself and do the same thing after running about 10 seconds.
Old Sep 5, 2005 | 08:31 AM
CCut's Avatar
Ok let me make sure I have theses hoses run right, the hose from my catch can goes to the throttle body right. and the hose from the valve cover goes to the side of the intake?
Old Sep 5, 2005 | 08:40 AM
SideStep's Avatar
I have an idea...
Do you still have a PCV??? If so, is there a chance you have it in backwards??? It is made to flow one way, easy to check and to fix.
Old Sep 5, 2005 | 02:34 PM
-Joseph-'s Avatar
No the inlet and outlet of the catch can goes in-line with the PCV system its routed close to the TB, but ends up connected to a plastic fitting on the intake. The hose from the TB only goes to the valve cover, change nothing on this hose from stock.
