What kind of heads are you running w/ your f13-14
Originally Posted by Charles Cyrus
Patriot's stage II 5.3s. F13 cam. Bolt on and go! 422RWHP/400RWTQ. 11.14@120mph.
Im running Patriot Stage II LS6's with F13, no track #'s or dyno #'s yet though.
Originally Posted by GuitsBoy
Your time looks good, but your dyno seems a little lackluster. There are cam only guys doing these numbers. Was this a mustang dyno by chance? Not that it really matters since the real proof is in your timeslip.
From testing we've seen a good cylinder head should pickup about 35-40rwhp. The last dyno testing we did resulted in a 39rwhp gain with the latest PRC port. Keep your eyes open for alot more dyno results coming soon, we're finally getting caught up on backorders Each PRC cylinder head spends 8 hours on the cnc machine, then 5-6 hours of additional finishing, extra porting & hand finishing before they ship! Alot of the cylinder heads go onto the flowbench 3-4 times for extra tweaking before they ship!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
That would make sense, but it says "Spec 2" and "Pro 5.0" in his sig...
Although its not one of the cams you listed, I have the F11 with Absolute Speed Stage II - 452rwhp/413tq through 4.10's.
My roomate (Winman) has the F11 and Patriot Stage II heads, he's doing 439rwhp if I remember correctly.
just installed my f14 heads are absolutespeed 2.5 5.3's with a 2.055 valve ground down to 2.04 heads are not milled i had no ptv problems but i do use comp r lifters dont know if that makes a difference with my tight valve lash spec or not?
ill have dyno numbers in about a week ill post them than.
Originally Posted by BriancWS6
Anybody out there with some AFR205s/F14, or TEA stg 1.5 5.3/F14 setup? That is what I am looking into when the time comes.
https://ls1tech.com/forums/generation-iii-internal-engine/375954-cam-spray.html check this thread there in the 1st response to the the thread user name pdd he has afr heads, i bieleve he had tea clean them up also by the sig? with an f-14 he can probley give ya some info!
Originally Posted by bad0211secws6
https://ls1tech.com/forums/showthread.php?t=375954 check this thread there in the 1st response to the the thread user name pdd he has afr heads, i bieleve he had tea clean them up also by the sig? with an f-14 he can probley give ya some info!
