Any advantage of Iron block over aluminum?
Are the cylinders any stronger? I think I cracked a cylinder at 17psi. It's hard to tell if the lines are cracks or not.
Cylinder number 3
Cylinder number 3
You need an Iron block. In your case I would not bore it. What reason did you pull the head and look for a crack in the first place. If you think that you did something to cause that crack and seen something as a result (smoke, fluid loss, power loss)from it, then it is a crack. The only way to tell is to pressure test, or to have done a leak down before you pulled the head. I have seen engines sit short lenghts of time in humid environments and leave patterns that look like cracks but was actually just rust in the cylinder.
Well, I fixed a BOV flange leak, and after running 14psi I hit 17psi (it was tuned for 14psi). After that it started missing (bad). Then I noticed blowby at idle (worse) [Edit: It was puffing out the oil fill breater at idle], did a compression test with cylinder 5 at 30psi, and 4 and 7 at 90psi (really bad).
That's what made me pull a head and saw the lines in cylinder 3 (pic above). I couldn't put my head where the brake booster was, but the camera saw my Diamond forged pistons were hurt:
Cylinder number 5
Cylinder number 7
Cylinder number 5
Cylinder number 7
I understand. I have used Wisecos before and like there product. They do recommend nitrous on them and they do have a very thick top land. I have never used them in a forced induction application. Friends LT1 looks the same as yours and he is running JE, he has a serious tuning issue and needs to be running a FAST (18 psi). It has happened to him twice and ruined two blocks.
Originally Posted by stang killer
I think its more of a tuning issue. LS1's dont break because of too much power.
