NO COMPRESSION....wtf?????
Old Oct 29, 2005 | 09:32 PM
  #121
CBX's Avatar
CBX
Originally Posted by 1BADAIR
You can't get compression if the rockers are off. Were is the air going to come from thats needs to get compressed
Your'e right, I meant loosen the rockers not remove. Must have had a brain fart.
Old Oct 30, 2005 | 06:44 AM
  #122
wicked_95z's Avatar
Originally Posted by TS6
How did you blow air into the cylinder with no compressor?
With my portable compressor...my lungs
Old Oct 30, 2005 | 07:01 AM
  #123
CBX's Avatar
CBX
How did you get your lips on the spark plug hole?
Old Oct 30, 2005 | 07:17 AM
  #124
Lasershop's Avatar
At this point I think the motor needs to be on an engine stand. You guys are beating your brains out. I think you said it was a used shortblock? Wouldnt it be funny if some dumbass assembled it with no rings (not from the factory). Sound ridiculous? Raise your hand if you have seen some really stupid **** done to cars! How many of you have seen totally butchered suspension? Process of elimination. Anyway, out of the car at eye level and start from scratch........ near a compressor. Thats what I would do. New stock head bolts cost almost nothing. Consider the past couple weeks just a loss (and then forget about it) and do it right even if your sure you already did. We have all done it. I pulled the A4 out of my Vette' (no easy task) just to make sure I had a snap ring where it was supposed to be. Turns out it was an extra one in the kit.
All that work for nothing but it had to be done. Or when you change valve springs and can only account for 31 locks. Crap!!
Old Oct 30, 2005 | 07:39 AM
  #125
wicked_95z's Avatar
I use the compression guage hose wiseass
Old Oct 30, 2005 | 12:36 PM
  #126
gearheads78's Avatar
Originally Posted by Lasershop
Wouldnt it be funny if some dumbass assembled it with no rings!
I was thinking the the same thing but surely somebody is not that stupid.
Old Oct 30, 2005 | 12:39 PM
  #127
strokedls1's Avatar
How do you know the valves are sealing? You may not be able to tell just by looking. Was that confirmed by a machine shop/ cylinder head shop. You will get compression with the rocker arms off. There is still air in the chamber. It's not like you get a vacuum condition because the intake valve isn't opening. I've done valve spring swaps were all the rockers are removed, and trust me it had lots of compression to fight me turning the motor over. I would have to agree that your problem lies with the heads.
Old Oct 30, 2005 | 03:40 PM
  #128
CBX's Avatar
CBX
Just kidding.
Old Oct 30, 2005 | 04:18 PM
  #129
wicked_95z's Avatar
I know..it was pretty funny though. You should have seen us trying to blow into the intake port. That was comical
Old Oct 30, 2005 | 04:35 PM
  #130
HASTINGSRJ's Avatar
but here's my thing. The heads came off a running car, went on to my running stock motor....and ran for 100 miles.....its a new short block, well new used anyways.....
Old Oct 30, 2005 | 08:46 PM
  #131
V6 Bird's Avatar
You say "no" and invite more talking? There is much to teach here.
I just like to watch the gestures and **** and how they make a fool of themselves trying to explain it..lol
Old Oct 30, 2005 | 10:38 PM
  #132
StickSS's Avatar
The New/Used block that you bought may have been honed oversized and somone put standard size rings on it that would make sense wouldn't it. Unless you actually saw the block in another car and saw the car running who knows whats going on in there. As said before just put one head back on with a new gasket and torque it down. Do a leakdown test on one cylinder with the piston at top dead center with the rocker arms removed. If you hear air gushing into the oil pan than you know the rings are bad.
Old Oct 31, 2005 | 06:55 AM
  #133
HASTINGSRJ's Avatar
I dont think the block has been touched, but your right that is a possiblility. However, when I picked it up, I took the factory heads and head gaskets off it myself. But I will try a leak down test, see how that goes. Thanks
Old Nov 3, 2005 | 03:24 PM
  #134
CBX's Avatar
CBX
ttt
ttt
Old Nov 3, 2005 | 09:19 PM
  #135
HASTINGSRJ's Avatar
well I had to order new head gaskets again tonight.....as I found out the 02 gaskets that I got, didnt match my 99 heads.....so hopefully they will be here by Saturday, so I can put this thing back together.....and finally drive it....
Old Nov 3, 2005 | 09:44 PM
  #136
so what did you find was wrong with it?
Old Nov 4, 2005 | 12:50 AM
  #137
Ed Blown Vert's Avatar
Was it the gaskets all along??
Old Nov 5, 2005 | 07:32 AM
  #138
HASTINGSRJ's Avatar
I dont think so....I think that the piston rings have dried up a little. I have been sick so I havent had a chance to look at it.
Old Nov 5, 2005 | 10:07 AM
  #139
Dried up a little rings don't cause 0 compression. It might be down but the gauge will still read. Open or bent valves cause 0 compression.
Old Nov 5, 2005 | 10:10 AM
  #140
TS6's Avatar
TS6
I give up, seriously, keep bumping the thread. How many ******* people have to tell you the same thing before you believe it? God I wish my problems were always this simple and obvious.......
