Cam swap - Lifter question/holding them up
I have spum my cam several times, but when I look into the hole I can still see the lifters (I have a boroscope). I thought the lifters went high enough for the rod to slide under them, but it doesn't appear to be the case. Car is a 2002 Vette.
How does the rod work, is it just friction against the side of the lifter?
I am afraid to pull the cam yet because I don't want a lifter to fall
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Not exactly sure what method you're trying but I used the trusty 'ol magnet trick. It wasn't even close to worth it for me to try anything less. The lifters are held in their bores simply by friction but each block/car is different and there are no guarantees at all that one will not fall unless it's retained by some trusted means. Please...tread lightly.
I have 5/16ths rod I was going to use, but I don't see what good it will do because the lifters are smooth and the rod won't go under them. I have spun the crap out of the cam and that is as high as the lifters will go. Not sure how the rod works, but on my car (2002) the rod would be towards the side of the lifter.
Restricted User
The rod slides in the block, holding the body of the lifter to prevent it from falling, NOT under it. It does NOT work on all LSx's, as some 01 & 02 have a different design lifter than the earlier models (crane vs comp). I have used the JPR lifter rods several times successfully but then again theres been 3, 2002's that will not accpet the rods. You can make some using a 3/16" velcro wrapped pass rod and a 5/16" drvr rod, plain round rod from Home Depot or Lowes etc.. Or use a mustang load of magnets.
I'm not sure what it looks like from the inside, but the rods are flat on one side and they are directional as well. As long as they slide in all the way your set but I have heard of some blocks having casting flashing in the way and not allowing the rod to slide in all the way.
Originally Posted by JS
Late model cars (after 02) dont work with the JPR I mean JPJUNK tool ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I used magnets.....
I used magnets.....
