Breaking in a cam
Old Sep 20, 2005 | 12:09 PM
02' hawk's Avatar
Default Breaking in a cam
How should i break in my new cam?
Old Sep 20, 2005 | 12:15 PM
777's Avatar
777
You don't need to. Just heat cycle the springs.
Old Sep 20, 2005 | 01:20 PM
PREDATOR-Z's Avatar
Yeap 2>3 heat cycles (meaning warming to operating temp, then letting completely cool off), that is all.
Old Sep 20, 2005 | 01:31 PM
02' hawk's Avatar
OK thanks, should i not let it get up past a certian rpm?
Old Sep 20, 2005 | 01:49 PM
Vax's Avatar
Vax
save your gas and keep it under 2k (drive it nicely)
you can go higher but its a nice precaution + saves you gas.
after 2-3 cycles you're safe to take it to redline
Old Sep 20, 2005 | 01:55 PM
777's Avatar
777
Don't go past 3,000rpms, but I see no reason why you would need to go past 2000-2500
Old Sep 20, 2005 | 02:50 PM
Bryan @ Speed Inc.'s Avatar
i heard you should run it at 2,000 rpm for 20 minutes. but i have no idea why that is.
Old Sep 20, 2005 | 03:03 PM
Brandon Boomhauer's Avatar
Thats for old school flat tappet cams.
doesn't apply to hyd. roller.
Old Dec 2, 2005 | 07:43 PM
02' hawk's Avatar
Thanks.
Old Oct 13, 2007 | 01:43 PM
xBROKEx's Avatar
you need to break in the springs not the cam
Old Oct 13, 2007 | 03:14 PM
gun5l1ng3r's Avatar
Aren't roller lifters great
Old Oct 14, 2007 | 11:35 AM
bad6as's Avatar
when you break in the springs should you just let it idle? or can you drive it but lik eyou said keep it under 3k. im gonna install the cam at a buddies place about 10 miles away and would like drive it home when i done to let it cool off over night. or should i just leave it their
Old Oct 14, 2007 | 12:10 PM
xBROKEx's Avatar
you can drive it, just keep it under 4k
Old Oct 14, 2007 | 10:02 PM
CodeName Z06's Avatar
If using new lifters do you need to fill them up with oil first?
Old Oct 14, 2007 | 10:09 PM
Blk97WS6's Avatar
when installing new lifters you want them to soak in oil over night.
Old Oct 14, 2007 | 10:49 PM
xBROKEx's Avatar
an hour or so is fine
N4cer's Avatar
Has anybody ever called the spring manufacturer to see if they're already properly heat treated and heat cycled? I know it's a free precaution, but just wondering.
