New front seal installation - hand press fit
Just installed my new front seal last night. Went in by hand. I thought about using RTV but the service manual doesn't call for it. I did a search and some are using RTV. The little lips I believe are meant to deform on installation and then seal and lock the unit in place as I tried to remove it and it wouldn't move much at all.
Has anyone installed the new seal dry, per the service manual, and had a problem with it?
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
I used a wooden 2x4 to soften the hammer blow.... no sealer, no leak.... the tricky part about avoiding leaks is aligning the cover. GM has a special tool for this.
Put all the bolts in and screw them by hand until they touch the cover. Then tighten in a few SMALL sequences like you would do for head bolts.....
This should help alignment.
Those using a block of wood and a hammer to install the front seal are not using the new seal GM has been selling for at least the last year. The new style seal presses in and out easily by hand and it is good to use some sealer around the outside edge of it before you install it in the t/c cover.
