Which cam for A4?
Should i go with a 112 or a 114, my car isn't a track car, i want the car to idle good and put down decent numbers, currently have flp headers, running cats, borla exhaust, was thinking of 2800-3000 stall with 3.73 gears. any opinions?
http://video.ls1tech.com/Player.aspx...BEBA&kw=87&p=0
Here is a walk around of my car, cut out open.
-Andre
That what i was thinking too, just wasn't sure if i should go with that cam with a 112 or 114, i was thinking a yank 2800 stall with 3.73 gears. i don't race, just wanted something that would be fun on the street.
I will tell you this you will regret not going with atleast a 3500 stall. And as far as cams its all about your goals power wise and sound wise. I dont go to the track but once in a great while and could care less about ET's. My goals were to have a fast/powerful car without sacrificing drivibility and I couldnt be happier. I'm averaging about 17-18mpg in the city, almost every stalled auto I have seen that is under 3500 have upgraded. But like I said its about what your goals/expectations are. There are plenty off 224 cams that make really good power tho.
Originally Posted by GotV-8
Ok, im not getting where the 112 and the 114 numbers are coming from...lol newb when it comes to cams..could one of u fill me in plz?
example 230/232 .589/.598 110 my cam
________duration___lift____LSA
Originally Posted by '99pewtert/aff
those are the Lobe Seperation Angle(LSA) numbers.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
D(irecto)r Pepper
224/224/ comp cam extreme lobes on a 114 is a sweet street track cam but a 112 will give similar perf while roughing up the idle just a hair. It's what i used to run some good times back in the day.
Originally Posted by Casperws6
isn't the F13 cam available on a 112 or 114 only? i could be wrong though ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
a cam with a 110 lsa. should idle well with a good tune
Thats mine idles around 950, and I love the way it sounds.
