LS6/LS2 heads.. what to expect?
Old Sep 28, 2005 | 09:10 PM
01Z0H6's Avatar
Default LS6/LS2 heads.. what to expect?
Was wondering what kind of gains "if any" with just simply bolting a brand new set of 04 Z06 heads ( yellow springs/ orange valves) onto my 02 LS1 block?
I don't really drag race... just something fresh... you know..?
Here are my current mod's...
thanks..
lid,k&n filter,pacesetter long tubes,lanes true duals,ported TB, LS6 intake, RPM4 232/236 .595 .601 @ 114+2, ASP pulley,HP tuners tune.. backed by a Yank SY3500....?
Thanks for your time...
porting/polishing gets pretty expensive...
Old Sep 29, 2005 | 12:58 PM
moeZ28's Avatar
LS2 heads are the LS6 heads.
Old Sep 29, 2005 | 01:04 PM
01Z0H6's Avatar
Wow... that helps...
Anyone else?
Old Sep 29, 2005 | 01:22 PM
redtail2426's Avatar
on a stock engine i think about 15-20hp and on a modded motor like yours with that cam i would say a good 20-25hp.be sure to reduce timing because of the improved combustion chamber.
Old Sep 29, 2005 | 01:34 PM
PREDATOR-Z's Avatar
15 > 20 is a good guess. You'll benefit from the bump in SCR and the slight increase in flow.
If you do so just remember to get the 04 gasket too, and PTV allowing a thinner gasket will improve that even more.
But I think assembled LS6 heads are like $1200 or so + gaskets and bolts. (unless used)
So You could get a nice set of ported ones for around that price (give or take a 100 buckaroos), Patriot, TEA to name a couple
Old Sep 29, 2005 | 02:05 PM
01Z0H6's Avatar
Now that is some good info...Thanks...!
Old Sep 29, 2005 | 03:30 PM
my01camaroz28's Avatar
Of course you will get better performance if you had them ported and polished, but the head stock isn't bad. I had mine that I just bought bench flow tested this week and will match a cam to those numbers. They almost can't be beat with the price I paid for mine.
Old Sep 29, 2005 | 04:05 PM
hey i bought from the same guy as you did a few weeks ago.would you be able to post the flow numbers you got?I sent mine to bo white to get fully done up.
Old Sep 29, 2005 | 08:01 PM
Can you send me some info on the guy or place you sent your heads? Is there a web site, contact numbers, pricing, etc? Here are the stock head charts too.
Attached Thumbnails LS6/LS2 heads.. what to expect?-file0006.jpg   LS6/LS2 heads.. what to expect?-file0002.jpg
