New Block and Heads from World Products !!!
There was some misinformation in my original post (sorry). Here are the correct specs:
- 9.24" and 9.8" deck heights. (9.24 is stock)
- Will swing a 4.250" crank
- 6 bolts per cylinder (yes six!), extra bolts are at 12 and 6 o'clock.
- The WP block or heads can be used with non world heads or blocks.
- The WP block has a priority main oiling system (GM's does not). That is why they have to run such high oil pressures... The thing that needs the oil the most, gets it last (crankshaft).
- The heads will be LS-1 or LS-7/C5-R Combo (LS-7 intake C5-R Exhaust).
I'll pass any further info as I get it.
This is going to be the cat's azz!
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
[B]
[B]
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
Hey All,
Some of the preliminary info was in this thread a while back.
https://ls1tech.com/forums/generation-iii-internal-engine/330018-4-125-world-products-bare-block.html
Most of the info here is pretty accurate. There will be a block at SEMA, but it will not have water jackets in it as of yet. The block coming to PRI should have the water jackets in it. The head availability will be nice also and along the same timeline. Get your wish list in line for Christmas.
On a side note, we have also gotten a couple 225cc Dart heads in for testing and show a lot of promise. As this info comes around I will pass it along.
Have a great day.
Mike Norris
Have a great day.
Mike Norris
I have heard rumor of the block and head combo dwarfing the current C5/6R block and head combination. Oh yeah, did I forget to mention that it will be cheaper than the C5/6R items.......??? Not to mention that there is someone out there in the head business (can not drop that name yet) that has already gotten 320+cfm out the head already.... and there are two intake cc sizes to choose from.
Looks like the LSx market competition just got a big shot in the arm.
Hey All,
A little more info for you. There is a possibility of a World Products block at SEMA with coolant jackets in them. Proposed ship date of the first prduction blocks will be 2/06 and quite a few orders are placed at this time. A World Products head will be there also, but a solid non-jacketed version for show. Chamber sizes are proposed at 58cc and 68cc options.
The Dart heads will be available in 205cc and 225cc runners as cast. Prelim 225cc tests show in the 310-315ish CFM as cast.
There will also be two other companies (not Edelbrock or All-Pro) releasing castings and assemblies not only in 205cc & 225CC versions, but also 240cc and 265cc in the LS1/6 style heads and also LS7/C5R styles. Intakes are also being developed as a complet package.
Bear in mind that with all of the aggressive packages there will be some differences. Though they will be bolt on in relation to cylinder head to block and intake to cylinder head, there will be some definite changes in the valve train area to keep geometry proper. At this time there are some folks using .200" long valves and related parts. But with some of these heads, .500" and .600" long valves will be required as well as different pushrod lengths from the norm. Some have higher valve cover sealing areas to clear most roller rockers and some are even offset. I mention this as often folks think a bolt-on is always simple and in this case there is a lot to consider in one of these aggressive head swaps. Nothing outrageous, just different then usual.
It will be an interesting trade show season to say the least. Hope this info helps. Thanks.
Mike Norris
Mike Norris
Okay guys, here's the 411 on the WP block and heads...
"Warhawk" Block:
- 357 T6 Aircraft aluminum.
- 4.00 Or 4.125 bore with .100 thick dry sleeves backed by .300+ aluminum.
- Crank case will accept 4.250 stroke with out modifications.
- Priority main oiling circuit (unlike GM that feeds lifters 1st cam 2nd crank last.
- Extra wide crankcase (like box pan) to control windage.
- Available 2 deck heights 9.240 and 9.800.
- Cam bores can be machined to 60mm.
- Available with both late LS1 motor mounts and early S.B. Chevy mounts.
- Provision for (Do not have to use) 2 extra head studs per cylinder for blown applications.
- Billet Main caps C5R style with ARP Studs.
- Can be wet or dry sump. Scavenge pick up at rear of block.
- All standard GM parts bolt on.
- $3799.99 retail price is 35% less then C5R.
086210
9.240 X 3.990, Billet Splayed Main Caps
$3,799.99
086220
9.240 X 4.115, Billet Splayed Main Caps
$3,799.99
086230
9.800 X 4.115, Billet Splayed Main caps
$3,999.99
WARHAWK Aluminum Cylinder Heads Replaces LS 1 thru 6
- 355T6 Aircraft aluminum.
- 15 degree valve angles.
- 220cc intake runner size.
- 2.080 X 1.600 X 5/16 valve size.
- 58cc or 68cc chambers.
- .750 thick deck.
- Uses standard LS1 valve train components.
025150
58cc Bare Casting
$649.99
025150-1
58cc Mech/Hyd.Roller 1.250"Dual Spring Assem.
$754.99
025150-2
58cc Solid Roller 1.437" Dual Spring Assem.
$879.99
025150-3
58cc Solid Roller 1.550" Dual Spring Assem.
$984.99
025250
68cc Bare Casting
$649.99
025251-1
68cc Mech/Hyd.Roller 1.250"Dual Spring Assem.
$754.99
025252-2
68cc Solid Roller 1.437" Dual Spring Assem.
$879.99
025252-3
68cc Solid Roller 1.550" Dual Spring Assem.
$984.99
The Warhawk 7X 12 degree aluminum cylinder head is the preferred alternative for LS7 and C5R.
- 12 degree valve angles.
- 255cc intake runner size.
- 2.200 X 1.625 X 5/16 valve size.
- 62cc C5R style chamber.
- LS7 intake manifold opening size and bolt pattern.
- C5R style exhaust port.
- Provision for 2 extra head studs per cylinder.
- .750 thick deck.
- Uses Standard LS7 Valve train components.
025350
62cc Bare Casting
$799.99
025350-2
62cc Mech/Hyd.Roller 1.437"Dual Spring Assem.
$1,029.99
025350-3
62cc Solid Roller 1.550" Dual Spring Assem.
$1,134.99
I hope this answers more questions. All prices are retail. I have not heard the max bore. 4.250" is the max bore on the iron block, not the aluminum. Given the cylinder wall thickness, I'm not sure you'd want to go to much past 4.125"... still, this still gives 454 ci capicaty.
I'll let you know if I hear anything else.
"Warhawk" Block:
086210
$3,799.99
086220
$3,799.99
086230
$3,999.99
- .750 thick deck.
025150
58cc Bare Casting
$649.99
025150-1
$754.99
025150-2
$879.99
025150-3
$984.99
025250
68cc Bare Casting
$649.99
025251-1
$754.99
025252-2
$879.99
025252-3
$984.99
- .750 thick deck.
025350
62cc Bare Casting
$799.99
025350-2
$1,029.99
025350-3
$1,134.99
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
So why didn't they make the bottom end similar to the ls1 and give it six main caps, or maybe they did I haven't looked at the .pdf yet that I got of this same topic in the force induction section.
"Warhawk" Block:
086210
$3,799.99
086220
$3,799.99
086230
$3,999.99
- .750 thick deck.
025150
58cc Bare Casting
$649.99
025150-1
$754.99
025150-2
$879.99
025150-3
$984.99
025250
68cc Bare Casting
$649.99
025251-1
$754.99
025252-2
$879.99
025252-3
$984.99
- .750 thick deck.
025350
62cc Bare Casting
$799.99
025350-2
$1,029.99
025350-3
$1,134.99
I'll let you know if I hear anything else.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
"Warhawk" Block:
086210
$3,799.99
086220
$3,799.99
086230
$3,999.99
- .750 thick deck.
025150
58cc Bare Casting
$649.99
025150-1
$754.99
025150-2
$879.99
025150-3
$984.99
025250
68cc Bare Casting
$649.99
025251-1
$754.99
025252-2
$879.99
025252-3
$984.99
- .750 thick deck.
025350
62cc Bare Casting
$799.99
025350-2
$1,029.99
025350-3
$1,134.99
- .750 thick deck.
- .750 thick deck.
