taking off the heads
Old Oct 14, 2005 | 06:23 PM
brandon1221's Avatar
Default taking off the heads
When i install my cam, I am also getting new lifters and heard you have to take off the heads to do this. I was wondering, will i have to buy new head bolts, or can i just re-use the old bolts?
Old Oct 14, 2005 | 06:33 PM
Mr. Luos's Avatar
You need new ones.
The factory ones are not re-useable.
Old Oct 15, 2005 | 12:34 AM
1jfuddle's Avatar
SDPC has great deals on stock bolt packages. For my own car, that is who I used. Less than $20 per side. Don't forget new gaskets too.
Old Oct 15, 2005 | 12:40 AM
BriancWS6's Avatar
Get new ones.
Old Oct 15, 2005 | 01:19 AM
Elite_Hot_Rod's Avatar
Why are you installing new lifters during the cam change?
Old Oct 15, 2005 | 03:04 AM
raven4960's Avatar
lifters wear with the cam. New cam and old lifters will cause problems...maybe not right away but the wear pattern on the old lifters will cause premature wear or failure with the new cam. On another note make sure to buy plenty of assembly lube!
Old Oct 15, 2005 | 10:04 AM
Mr. Luos's Avatar
The LS1 cam is not a wear item.
Most guys that do the cam swap use the stock lifters. I haven't heard of any wear problems.
Old Oct 15, 2005 | 10:10 AM
destroyerSS's Avatar
How many miles are on your car? What cam? I installed 2 different cams in my old motor and never touched the lifters. NOTE: If you are removing the heads the stock ones better not be reinstalled What you should do is replace your springs and pushrods Good luck ,Shawn
Old Oct 15, 2005 | 10:42 AM
98UltraZ's Avatar
http://cgi.ebay.com/ebaymotors/BRAND...06250332QQrdZ1
I have some brand new head bolts I never used. They are on ebay right now for $5.50 with no reserve... They end tomorrow, and I am charging a flat $13 for shipping.. If you win them for $6.00, you would have a brand new set of bolts for both heads for under $20 shipped.
Old Oct 15, 2005 | 10:59 AM
jaredm's Avatar
get head gaskets too. i paid about 50 for the set. individually they are more expensive. same with the bolts. i'll try to find the part #'s so you can save some money.
Old Oct 16, 2005 | 11:03 PM
I am getting the f-13 cam, and i wish i had money for new heads right now, but I dont. In the post I made about the cam, alot of people seemed to think new lifters would be a good idea too, just added safty with revving to 6,800. My car has almost 80,000 miles and i prob. wont have enough money to buy heads for my car for a longgggggggg time.
Old Oct 17, 2005 | 03:03 PM
HectorLS1's Avatar
Buy the new lifters. I wish I did it.
