heads for a 402 0r 408? cam?
Old 10-29-2005, 01:02 AM
SSilverSSurfer's Avatar
Default heads for a 402 0r 408? cam?
are the stock heads able to be ported to handle either? and wat kind of cam are you 40x guys running?
Old 10-29-2005, 01:33 AM
ArcticZ28's Avatar
Eh, not really worth it. Some people use the stage 2+ LS6 heads on the 40x's, but I personally think the best start you can get is with the LQ9 (317) heads. They are a great starting point for porting. It's all a matter of preference and what static CR you want to run.
As for the cam, I'm gonna say the "typical" cam is in the mid 240's duration on 402/408's. However, that also depends on the person's static CR and what dynamic CR they want to run (aka how much they want to bleed off, having to do with LSA, overlap, etc... way too much to get into).
Old 10-29-2005, 02:14 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I bet most would tell you AFR 225's as an easy out...but that would only be easy for me if someone "gave" them to me!
Old 10-29-2005, 01:23 PM
same here thats why i was asking about porting the stock heads.... im starting to think after seeing those cam durations i might have to do a 382 for a daily driver....what do you guys think?
Old 10-29-2005, 01:45 PM
Mr. Luos's Avatar
Patriot Stage III LS6 heads
TSP 248/254 629/622 113
TSP LQ9 402
Not running quite yet.
Old 10-29-2005, 02:47 PM
sounds like its gonna be a monster good luck Luos
Old 10-29-2005, 03:08 PM
Mr. Luos's Avatar
Thanks.
So far so good. Weather has been trying to keep me outta the garage though.
Old 10-29-2005, 09:56 PM
sorry to hear that....hope everything comes out the way you plan
Old 10-30-2005, 07:43 AM
383ss's Avatar
I'm running a $1500 dollar set of 5.7L stock heads and making 550rwhp on my 408. they are maxed out, but thats still pretty damn good power, IMO. PM me if you want to know the company, they are a non sponsor.
also, DON'T look at high lift numbers. mine 'only' flow 293 @ .600 lift
