who is running 5w40 amsoil
Old Nov 4, 2005 | 09:54 PM
o2man98's Avatar
Originally Posted by dailydriver
Not to hijack the thread, but Patman (or anyone) how do you rate the current high quality/performance filters?? I know you once had a problem with the Mobil 1 filter at higher revs? How do the Amsoil SDFs stand up/compare?
FYI The Amsoil SDF Filters are no longer in production and state obsolete when I try to order online. The new replacement filters are the new EaO filters. These are very impressive filters and I think they will surprise the filter industry.
Old Nov 4, 2005 | 10:03 PM
10thAnivHawk's Avatar
how is the royal purple oil? about the same? I'm runnin that right now there is a shop fairly close to where I live that carries it so I don't have to order it.
Old Nov 5, 2005 | 01:26 AM
RollinSScamaro's Avatar
What kind problem with higher revs? Power loss or oil pressure loss?
I have always used the Mobil 1 filter thinking it was one of the best.. I gues si'ma sucker to big name brands sometimes though!
I may try K&N out.. let me know the prob with the Mobil filters though?
Old Nov 5, 2005 | 02:01 AM
BlackHawk T/A's Avatar
I use Amsoil 0-30. It says on the bottle once a year or 35k miles. I will go one year however I think I will move to 10-30 next time to quiet things down a bit, though I believe the 0-30 would be superior at startup.
Old Nov 5, 2005 | 06:04 AM
Brianss1's Avatar
I just did the oil change and the oil filter I got was the SDF32.Will see how long this oil stays clean and how it holds up as far as consumption and usage.Also BlackHawk T/A 10w-30 not worth it use 40 weight.Thats just my opinion though.
Old Nov 6, 2005 | 02:17 PM
dailydriver's Avatar
Patman, do you have an explanation, or did I hear/understand wrong?? If I recall correctly it was a high rpm flow problem?
Old Nov 6, 2005 | 02:56 PM
A 0-40 would be ideal actually...
Old Nov 6, 2005 | 03:10 PM
ZLEEPER's Avatar
I have a question for you Patman. I switched to the 5w-40 amsoil in my 402. It never used any oil before, but now I'm noticing some consumption. I was running 4qts 10w30 + 2qts 15w50 Mobil1. Was wondering if I might just need to move to a 10w-40. Tia
Old Nov 6, 2005 | 05:03 PM
transAm-98's Avatar
i've been using amsoil 10w40 since i got my cam in. oil pressure goes up a few points and valvetrain quiets down bit compared to mobil 1 10w40. luckily one of our local speed shops started stocking amsoil, so now that it's readily available i wouldn't go with anything else.
Old Nov 6, 2005 | 09:17 PM
ZLEEPER's Avatar
has anyone had an issue with oil consumtion with the european 5w-40?
Old Nov 7, 2005 | 10:36 AM
Does this exist??
Old Nov 7, 2005 | 12:13 PM
  #32
Not sure...
For this 5-40...you guys talking about the European stuff? Amsoil has multiple kinds and its kinda confusing...
Old Nov 7, 2005 | 04:14 PM
  #33
bad6as's Avatar
0-40 mobil 1 makes it so does amsoil
Old Nov 7, 2005 | 06:38 PM
  #34
Patman's Avatar
Amsoil's 0w40 is not really for use in automobile engines though, it's more of an ATV/Snowmobile type of an oil, and it's not rated for extended drain intervals either.
Old Nov 7, 2005 | 09:31 PM
  #35
o2man98's Avatar
Not sure...
Yes the European 5w-40 Product Code - AFL
Here http://www.amsoil.com/storefront/afl.aspx?zo=1132530
Old Nov 8, 2005 | 03:10 AM
  #36
I think this is the stuff i'll be trying next oil change. I'll see if piston slap quiets down from my Amsoil 0-30.
