ET performace 240cc or 225cc heads?
Old Nov 4, 2005 | 10:36 PM
SMDLS1's Avatar
Default ET performace 240cc or 225cc heads?
I need some advice, I have a 402 LS2 being built by TSP right now and I dont know which heads to use the 240cc or the 225cc ET performance heads. The cam is a 248/254 .622/.614 114lsa and the car has an A4 with a 3200 stall and 3.73 gears. It also has the fast 90/90 setup and kooks 1 7/8 headers. The motor is being built to handle 300 shot and will have a progressive 200 for the track. The car is a full weight street car, so I do not want to give up low and mid power for peak hp. It will only see the track about 5 times a year. Hope this is enough info to give me the best advice. Also do think this will be a good cam for what Im looking for performace wise. Thanks in advance, Shane
Old Nov 4, 2005 | 10:49 PM
Brandon Boomhauer's Avatar
from what carry said here link the 240s should be the choice ona 400+ motor.
Old Nov 4, 2005 | 10:58 PM
black01_WS6's Avatar
for what you have planned you should go with the 240's. you have a good set up going. how much for the maf kit and ported tb.
Old Nov 4, 2005 | 11:19 PM
Cary@Perf-Induction's Avatar
Collections Hold
Default heads
the 240 will be best suited for your combo.
Old Nov 4, 2005 | 11:22 PM
ls1408cp's Avatar
thats what LME is putting on my 408 the et240s
Old Nov 4, 2005 | 11:54 PM
SMDLS1's Avatar
Thanks,what about the cam I have listed?
Old Nov 5, 2005 | 06:29 AM
Blktie8's Avatar
Yep!
PM me for your cam :
Old Nov 5, 2005 | 12:49 PM
SMDLS1's Avatar
Anybody else on a cam suggestion for my setup??
Old Nov 6, 2005 | 12:09 AM
xxxhp's Avatar
Since that you're going with ETP heads, why don't you choose one of the new COMP LSK lobes which have higher lifts? I think this way you'll get the most out of those ET heads since their flow really shines at higher lifts
