Dart "as cast" test
Old Dec 6, 2005 | 07:41 PM
  #41
383ss's Avatar
Originally Posted by Dart331Stroker
The manifold was an out of the box manifold. The SAE corrective factor really makes this motor look to be down in power compared to what you guys have seen on chassis dynos and such. The whole factor here is to compare another companies (one that is mentioned often on here) cnc fully ported heads versus a run of the mill as cast Dart head. Dart is going to offer fully ported heads that will be priced right in line with the rest and after looking at how well the as cast does versus ported heads, Dart should be fine in the cnc market.
when are we going to see some of these fully ported heads?
Old Dec 10, 2005 | 07:10 AM
  #42
WKMCD's Avatar
Who is making dual springs for the DART heads or do drop ins work like PP Golds and 921's?
Old Dec 10, 2005 | 08:57 AM
  #43
rjw's Avatar
rjw
From: Tinker till it blows, then back it off a notch, maybe!!
Springs that fit OEM head will fit the Dart. If mods are needed with the OEM then they will probably be needed with the Dart as well
Old Dec 11, 2005 | 01:40 PM
  #44
JS's Avatar
JS
Kurt can u test the Dart 205 on a 346CI with small cams and medium cams too?
Old Dec 11, 2005 | 04:37 PM
  #45
vettenuts's Avatar
Curious as to why you are interested in this? The Dart springs are somewhat light on the seat (125#) but they have a pretty high spring rate and are beehive design so there is less accelerated mass.
Old Dec 11, 2005 | 10:13 PM
  #46
427's Avatar
427
Sorry can't help you with that one. We are testing heads for our crate engine's. They are 402ci at this time. We may add some other sizes in the future, but it probably will not be the 346.
Kurt
Old Jan 1, 2006 | 09:18 PM
  #47
red90cobra's Avatar
Kurt do you have the results after touching them up and doing bigger valves?
Old Jan 1, 2006 | 09:33 PM
  #48
DavidNJ's Avatar
What was the ignition timing with the different setups?
Old Jan 3, 2006 | 07:23 AM
  #49
427's Avatar
427
We held the timing steady at 30 degrees.
Kurt
Old Jan 3, 2006 | 07:44 AM
  #50
427's Avatar
427
Dart 225--------competitive priced 5.3 head--Dart head with carb/Eldebrock intake(-------SAE Correction--------------)
rpm--tq---hp---tq---hp---tq---hp--tq--hp
3000-428-244--407-232--387-221--404-231
3500-412-275--399-266--392-261--399-266
4000-465-354--447-341--444-338--453-345
4500-487-417--472-404--487-417--489-420
5000-490-467--472-450--501-476--504-480
5500-473-496--459-480--484-507--489-512
6000-446-510--428-489--454-519--466-532
6100-440-511--422-490--448-521--461-536
6200-433-512--415-490--443-523--459-542
6300-425-510--408-489--435-523--455-546
6400-417-508--399-486--426-520--448-547
The last row of HP and TQ is with mild portwork and 2.08 valves. This is in SAE correction(factory) on a engine dyno. The test was ran with the Holley carb and Edelbrock intake.
That same dyno run in Standard correction (29.92Baro-60F) was 529ftlbs and 575hp.
The actual raw power at the crank with no correction factors on that run was 537ftlbs and 585hp. At the time of the run humidity was 55% temp was 31f and baro was 29.51.
Kurt
Old Jan 3, 2006 | 09:02 AM
  #51
Reckless's Avatar
Super Moderator
Temp in the dyno room was 31*F Kurt? Can't you guys afford heat?
Great info!
Old Jan 3, 2006 | 11:09 AM
  #52
383ss's Avatar
Kurt
am I reading that right? you picked up 27hp@6400 going to a bigger valve and mild portwork? its kind confusing to read...
wish you'd spin it another 500rpm looks like gains are going up nicely as rpm increases.
Old Jan 3, 2006 | 12:50 PM
  #53
red90cobra's Avatar
Kurt
not bad kurt can you pm me a price for those heads
Old Jan 3, 2006 | 01:37 PM
  #54
427's Avatar
427
It is hard to read, but you are reading it right! Power peak on all runs was at 6400rpm or lower.
Kurt
Old Jan 3, 2006 | 02:07 PM
  #55
calongo_SS's Avatar
Just curoius, what was the temp for the previous runs?
Impressive gains for mild portwork.
Old Jan 3, 2006 | 02:27 PM
  #56
427's Avatar
427
The runs are all corrected to 77f, the actual temp stays within 10 degree's in the cell.
Kurt
