Scat I-beam rods
Old Nov 23, 2005 | 10:49 PM
FastKat's Avatar
Default Scat I-beam rods
Anyone use the Scat I-beam rods in their buildup? Any comments on those?
Thanks, -Dave
Old Nov 23, 2005 | 10:52 PM
Beast96Z's Avatar
I'm using the SCAT h-beams in my current build. No testing as of yet, but nice pieces.
Old Nov 25, 2005 | 11:18 AM
FastKat's Avatar
Thanks, anyone else?
Old Nov 30, 2005 | 11:39 PM
FastKat's Avatar
Hmm, doesn't seem to be much on these?!
Old Nov 30, 2005 | 11:57 PM
Turbo LS1 SS's Avatar
i have h beams rods in my car....5k miles, no problems yet
Old Dec 2, 2005 | 09:38 AM
FastKat's Avatar
Cool... sounds like the H-beams are good, but how about the I-beams?
Old Dec 2, 2005 | 01:15 PM
Brandon Boomhauer's Avatar
arent the I beams just a little heavier?
any reason for going with the ibeam on your end?
Old Dec 2, 2005 | 01:18 PM
FastKat's Avatar
Yea, they're like $180 cheaper and I am not going to be exceeding the stock 6200rpm redline. High RPM's really test your rods.. and since I am keeping the RPMs down, there's no need for a bullet-proof rod.... however I would prefer something forged over my 80k mile powdered metal rods. If the I-beams are a little heavier, I can deal with that. I just don't want to buy junk!
Old Dec 2, 2005 | 01:38 PM
what kind of buildup are you doing....
reason why i ask is, obviously scat is a budget rod, and id be lying if i said i wasnt nervous about having them in my 700hp FI buildup this year. reason why i picked them last summer is becuase the motor blew and the money wasnt there. is this a turbo/sc or nitrous engine? what kinda power u lookin at.
like i said, these have been good to me so far, but u really dont wana cheap out when ur spending that much in the first place u know....
Old Dec 2, 2005 | 01:43 PM
why do you say scat is a budget rod?
the i beam is more of a budget yes, but nothing wrong with other scat stuff.
Old Dec 2, 2005 | 02:13 PM
STANG KILLA SS 2's Avatar
scat is budget forged stuff. pretty much the bottom of the line forged peices...
not saying there anything wrong, however, fastech did tell me to stay away from them...recommended crower
Old Dec 2, 2005 | 02:45 PM
hrmm
ok.
i've heard of some of the billy badass high dollar pro billet rods bending well under their 'range' too...
Old Dec 2, 2005 | 03:25 PM
anything can and has been broke...dont matter what power range their in....
of the cars makin power...***** gona brake
Old Dec 2, 2005 | 03:30 PM
FastKat's Avatar
I'm doing a turbo setup and building for between 600 and 700rwhp, and trying to keep costs under control... I'm sure most of you know how hard that is! I also see that A LOT of guys on this board have a tendancy to overbuild their motors. Really what I want to know is what kind of low-dollar rod can I get that isn't "junk". Would I be better off with an Eagle I-beam rod, Scat I-beam rod, or maybe a different brand?!
Old Dec 2, 2005 | 11:32 PM
J&J Speed Shop's Avatar
I would consider the CompStar rods or Lunati ProMods at those power levels. I know the CompStars are still budget but they have ARP 2000 bolts, the finish machining is excellent, and the weights are very consistant and I have used them in a 650 rwhp engine, and wouldn't see a problem using them up till around 800rwhp
Old Dec 3, 2005 | 04:50 PM
FastKat's Avatar
That sounds like a lot of rod! I'm looking for the most bang for the buck... I don't understand how people rate rods at a horsepower level.. rod loads are ultimately the function of 1) the mass of the piston/pin/ring and 2) the engine speed? Any rod will fail if you spin it fast enough, whether it's putting out 100hp or 1,000hp.
Anybody know of any inexpensive rods that aren't "junk"?... and by that I mean have a decent quality of workmanship.
Old Dec 3, 2005 | 05:31 PM
Wet 1's Avatar
The Scat rods have lived at over 1100 hp in a turbo LSx engine. For what you guys are going to do with them, they should more than enough rod.
Old Dec 4, 2005 | 01:46 AM
FastKat's Avatar
Scat I-beam or H-beam... the H-beams seem to be the most popular, but also the most expensive.
Old Dec 4, 2005 | 04:33 AM
AsianIce25's Avatar
700 at the tires is a lot of power...why use cheap crap??? not saying scat is cheap, but go H-beam not I-beam. $180 is still cheaper than throwing a rod through the block. go big or go home.
Old Dec 4, 2005 | 07:36 AM
PREDATOR-Z's Avatar
Really though, stock rods can take that much horsepower, it is usually the rod bolts that let go not the rods thenselves. The SCAT rods wil be fine if you are budget concerned.
