Valve spring compressor tool question.
Old Dec 1, 2005 | 07:32 AM
CBX's Avatar
CBX
Default Valve spring compressor tool question.
What valve spring compressor tool do you guys use on an LS engine? I've been looking and there is a wide price range, but I'm not sure whether or not they will all work. For example, Summit has a Proform stud mount compressor, Summit part no. PRO-66784, for $49.00. Will this work?
Thanks in advance.
Old Dec 1, 2005 | 08:19 AM
Z'mnypit's Avatar
Do a search on the "Larry tool" then just go make you one like that. It would be the chepaest easiest way.
Old Dec 1, 2005 | 08:20 AM
Griswold's Avatar
I have the tool from crane. It is a little more expensive, but worth every penny. I can't imagine changing springs on the car without it.
Old Dec 1, 2005 | 08:36 AM
CBX's Avatar
CBX
Do you know the part number? Where did you buy it? Thanks
Old Dec 1, 2005 | 01:01 PM
ROCNDAV's Avatar
I bought mine from Vinci when they had a GP/sale on them a couple of months ago. I had to modify mine with an air grinder to get it to work with my AFR225's and PP gold spings. It didn't bother me as I figured that it was designed for stock set ups.
Old Dec 1, 2005 | 01:04 PM
smithsc's Avatar
I bought mine from More Performance.
Small enough to get tot he back couple of springs in the Z06 anyway.
Steve
Old Dec 1, 2005 | 01:34 PM
jerflash's Avatar
another vote fot the crane tool
simple, easy to use, lok profile for getting to the back ones, and does intake and exhaust at the same time!!
Old Dec 1, 2005 | 01:51 PM
ArKay99's Avatar
Same here, same issue but with AFR 205's. No problem though once modified to fit, it works great. About $120 and you can do the intake and exhaust at the same time.
Old Dec 1, 2005 | 01:56 PM
jerflash's Avatar
you know whatmakes it even easier?
havin the right size gear wrench
Old Dec 1, 2005 | 02:13 PM
ROCNDAV's Avatar
what do you mean?
Old Dec 1, 2005 | 02:19 PM
jerflash's Avatar
you get under the cowl with the crane tool it makes turning the nut that compresses the valvesprings even easier and quicker to turn
Old Dec 1, 2005 | 02:31 PM
Steve Burger's Avatar
LS1TECH Sponsor
Another vote for crane
Old Dec 1, 2005 | 03:05 PM
ROCNDAV's Avatar
Ah! I haven't had that joy yet I've only been messing with my LS1 on the engine stand.
Old Dec 1, 2005 | 03:29 PM
jerflash's Avatar
well i havent had that yoy yet either and dont plain on it to soon
i will change my heads before a wear out my prc golds
i ran out of money and had to out my stock untouched heads back on my motor for now haha
Old Dec 1, 2005 | 03:36 PM
Black Z/28's Avatar
Crane here as well. I've done (2) sets with the crane tool. Very nice.
Old Dec 1, 2005 | 03:52 PM
Keenov's Avatar
I used the crane tool and it was a breeze!
Old Dec 1, 2005 | 04:05 PM
jay_99z's Avatar
Steve
Done 4 or 5 spring swaps with mine. Little pricey but it works great.
Old Dec 1, 2005 | 04:12 PM
mrr23's Avatar
vinci high performance 99.99
Old Dec 1, 2005 | 04:24 PM
JC5's Avatar
JC5
Crane is a great tool! Vinci's service is also great!
Old Dec 1, 2005 | 04:34 PM
Var's Avatar
Var
The Crane tool is worlds better than the More tool. I used the Crane tool just last night. I couldn't believe how easy it was to do the valve springs.
