Futral F10 owners inside
My input on that is lifter preload. I think it has to do with base circles and that 7.40 p-rods are a little short.
on my XE-R lobes, I reduced that "sewing" effect with .025 longer p-rods.
I run 7.425's.
I must say that I have a slight "whine" or "whistle" at WOT...I'm thinking it's either a very small exhaust leak (I have MACs) or it's normal...
I run 7.425's.
) The Best V8 Stories One Small Block at Time
http://www.thunderracing.com/catalog...vid=3&pcid=106
. The point I was making was that if this was a common issue with the BC of the Futral cams, wouldn't you think they would offer the longer rod? Last edited by GMCVT; Dec 1, 2005 at 11:53 AM.
. The point I was making was that if this was a common issue with the BC of the Futral cams, wouldn't you think they would offer the longer rod? Base circle is relative to lifts used, so I guess they simplify things for mass sales.
you'll notice that this is an issue with non adjustable rockers, but with adjustables you can absorb these differences.
Beeing on this board for awhile, I've read many "noisy" posts, "lifter failure" posts etc.. most due to improper preload on lifters and/or poor geometry.
As a matter of fact, I have 4 sets of Comp p-rods (from 7,350, 7.400, 7.425 and 7.450). Those are what I use to get the closest preload with stock rockers when I change cams.
I just haven't got myself to spring for a set of adjustables yet (they all have clearance issues). The ones I like the most are CRANE "Gold" but with milled heads (or aftermarket castings), you run into the same situation.
This is what I do sometimes >>>
As a matter of fact, I'm going with a TSP 232/234 113LSA+0 soon (Torquer Rev 2) and I think I'll be doing some more head bashing.
I did it exactly as written and I have ZERO harmonic problems.
To determine the right preload:
Once the rockers are sitting in the right place, use a 10mm socket and extension but NO SOCKET WRENCH, and finger tighten the rocker arm bolts until both of the bolts get too tough to spin with 2 fingers. You can take your index finger and try to spin the pushrod under the rocker arms as well, and it should have some friction on it and just barely spin, if spin at all. This is called "Zero Lash" and it is where there is no preload on the lifters....the lifter is touching the pushrod, the pushrod is touching the rocker, and the rocker is touching the valve, all without putting any pressure on the lifter.
NOW, get your socket wrench out and attach it to the 10mm socket+extension you were using. Without turning the bolt AT ALL, place the wrench in the 12 o'clock position. What we have to do is count the bolt turns until the instant the bolt gets hand tight. Turn each of the two bolts 90 degrees clockwise, then set the wrench at 12 o'clock and repeat (do each bolt one 1/4 turn, and keep alternating).....each 1/4 turn per bolt seems to equate about 10-12 thousandths preload (this is a very rough guess!).
If you get MORE than 1 full 360 degree turn on each bolt, remove the rockers and install the shims on the bottom of the pedestals and repeat this process to check the new preload. The shims seem to reduce the turns by approximately 270 degrees. You must install a shim on BOTH bolts, not just one or the other. If you got LESS than 1 full 360 degree turn then you are ok to leave the shims out!
Every car will be different so make sure you check this! You want the smallest number of turns you can get, as long as you have at least 1/4 or 1/2 full turn of preload in there once you are all setup. If you get to the point where the bolt is tight yet you can still spin the pushrod (without using shims), then your pushrods are either too short, your valves are too short, or you have some strange valvetrain geometry. You MUST have some preload or it will be OBSCENELY loud and run very poorly. Longer pushrods may fix your issue in this case.
Once your geometry is correct, then you adjust your preload via p-rod length.
Since stock rockers are non adjustable, to get exact preload would be a miracle.
22ftlbs and no finiking with turns.
Most likely you should end up with a p-rod that gives you a preload closest to, without going over .060 >.080 (hot)
BTW this is a thread that might interest you.
https://ls1tech.com/forums/generation-iii-internal-engine/370412-lost-power-incorrect-length-pushrods.html
https://ls1tech.com/forums/showthread.php?t=370412
wipe test will determine if your rockers are at proper height
Wipe test determines correct geometry and preload to a certain degree, p-rod length only affects lifter pre-load (this is because we run hydraulics, ie LSx specific with pedestal rockers).
Now that you know that your geometry is correct, you need to measure your lifter preload to determine what length rod you should run.
Now with stud mounted rockers (Comp Magnum) for expl, your method is correct.
, so last night I went out and put two rockers on base circle, 0'd the lash and I had to turn the bold 1 to 1 1/4 of a turn to hit 22lb ft. To me, that means that I need a shorter pushrod. The pushrod is sitting higher than it should which would require more overall turns to get it to 22 lb. ft. Am I wrong? But that is done with motor warm and lifters pumped.
If you want I have a pushrod length checker that I bought from thunder and I can mail it to you if you want to borrow it.
