How do you guys classify "CAM ONLY"
BTW my cars:
1991 Lumina 4-door 3800 Series II Whipplecharged - 12.545 @ 108, 1.8 60'
1997 Grand Prix GTP stock + Whipple - 330 hp / 440 tq - 13.3 @ 100, 1.9 60'
Dads car:
1998 Vette C5 Concepts "Thresher 450"
IMHO a cammed engine with full bolt-on mods, headers, intake, tune, etc... but stock heads, pistons, connecting rods, and crank is a cam-only engine.
Blue Hawk posted what he considers "cam only", is this what everyone here considers cam only or is it one guys opinion?
Now we all know that when you change the cam, you also change springs, retainers, p-rods, and sometimes t-chain.
I've described my cam only before with a head gasket change (.045 instead of .054 graphite) and I was jumped on that this was not cam only. But the heads were untouched.
So relatively speaking it is a loose term.
This is probably the most reasonble definition that I have heard of and it does make sense. Now Matt, if you caould have explained it like this a month ago, that would have saved the internet from all the useless posts on wichitaracing about it
. When you start getting into electric water pumps, underdrive pulleys, throttle bodies, intake manifolds etc..you are disqualified IMO.
The reason i count in exhaust is cause the car wont run well with a big cam and restrictive exhaust, but it can run well as everything remains stock.
Electric water pump, pulleys, tb, intake manifolds, bigger MAF, etc..all these things are completely on their own and can vary the power difference by as much as 40 horsepower..so it defeats the term "cam only" which is a term people use to get a general understanding of power vs speed. + or - 40hp is not an acceptable window IMO.
Cam-only should also be a term more oriented to the whole car, rather than just the engine. Again we use the term for a comparison for how much faster a cam makes you go. Stalls and gears can greatly vary the numbers too therefore should be disqualified.
I think most everyone else have been right. Pretty much whatever boltons and supporting mods that are needed, desired, whatever. Just as long as the heads and rotating assembly are left untouched.
i'd say cam only is no heads, no power adders, stock bottom end, everything else is game.
