f14\15 vs g5x4 vs ms3 vs trex
Old 12-02-2005, 02:51 PM
Bryan @ Speed Inc.'s Avatar
well LG is wrong!!! lol. just kidding. im sure you'll be fine with that stall. but seeing that the car is mostly for fun, (not a daily driver) i'd stick a 4k+ stall in there w/ a 4.10 gear.
you want your car to be a beast??? that'll help get you there.
Old 12-02-2005, 03:01 PM
Brandon Boomhauer's Avatar
I liked my FMS F14, but it pulled HIGH.
I havent seen anything really impressive out of F15
Take LG's advice if you are going through them, they know what will work best for a setup with their cam, and their AFR heads (what they do besides mill I dont know).
Old 12-02-2005, 03:03 PM
algws6's Avatar
i would PM louis or talk to Lou directly and see what they recomend.
Old 12-02-2005, 03:36 PM
CBX
CBX's Avatar
Originally Posted by LS1 BU
With that stall I think an F14 at the most. I would personally run a f11-f13.
I just ordered a Fuddle 3400 stall. I was told by many people including John Fuddle, that my cam (F11) would be perfect with a 3400 stall. I think you would need a bigger stall for those other cams. I considered the cams you are thinking about, and the more I thought about it, those cams like to make their power up really high in the RPM band, not exactly the best for the street. I will make a lot more low and mid range power with my F11 on a 112 LSA. In fact, lots of people have awesome results with a 224 cam. Just my opinion.
Old 12-02-2005, 03:45 PM
SSU's Drunk Typing Whore
Lithium's Avatar
MS3 and some PRC 5.3 2.5 Heads.
Old 12-02-2005, 04:17 PM
mike c.'s Avatar
i have the g5x3 w/afr 205 heads. the results are 11.1@124mph m6,stock weight car. the x3 cam only peeked out at 6,400rpm's on my car and held on with only a small drop in power ti'll 7,000rpm's. next year i'm trying the x4 cam. goodluck to ya bro.
Old 12-02-2005, 04:49 PM
LS1 BU's Avatar
I had the x3 with a 4000 stall and thought it needed a bigger convertor. Made big power on the dyno but didn't run good. Made 429 rwhp and 390 rwtq through a ford 9 inch with a spool. But only ran 11.55 at 116 mph.
Old 12-02-2005, 05:32 PM
CBX
CBX's Avatar
Why go to the X4? Those are some nice numbers.
Old 12-02-2005, 05:39 PM
FormulaFire's Avatar
What were your dyno numbers? And what other mods?
Old 12-02-2005, 05:52 PM
ssheets's Avatar
Hmmm, I have an F14 and worked 5.3 heads. I haven't installed them yet, but I talked to Futral a few times about the setup. I was told max intake valve of 2.02" with max milling of .010" We milled about .007". I'm going to measure PtoV prior to selecting my gasket.
The 5.3 heads have a .030" lower ceiling than the 5.7.
I wish I could tell you my actual measurements, but I'm still looking at a few months (maybe 3-4 ) for some warmer weather before I dig in.
Old 12-02-2005, 06:20 PM
FUN LS1's Avatar
Originally Posted by imslow
is this true????
Yeah the AFR heads have a thicker deck, right?
Old 12-02-2005, 07:23 PM
  #32
Jpr5690's Avatar
humm.... this whole g5x3 thing is soundin good... but instead of milling is there a good way to use gaskets to solve the issue or will this result in power loss?
Old 12-02-2005, 07:36 PM
  #33
HaulinHawk's Avatar
G5X3 here also,3800 stall ,4.10s and its badass!!!!!!!!YOU WILL LOVE THE IDLE ALSO!!!!!
Old 12-02-2005, 11:47 PM
  #34
Hennytime's Avatar
did you have to flycut or do anything special to make it all fit well? what type of power did it make on the dyno
Old 12-03-2005, 06:42 AM
  #35
King James's Avatar
Do you have any dyno numbers or track times?
Old 12-03-2005, 11:13 AM
  #36
Billnz28's Avatar
Why not go with the g5x2 on a 112 with milled afr 205 from LG.
Old 12-04-2005, 02:36 AM
  #37
Jpr5690's Avatar
whatta about the g5x4 too big?
Old 12-05-2005, 07:49 PM
  #38
Jpr5690's Avatar
ok now im back to the prc setup ive heard a few folks say the x4 is gonna be too big ..
Old 12-05-2005, 08:24 PM
  #39
Lithium's Avatar
I still say MS3 and some PRC heads. I am going with that myself.
Old 12-06-2005, 12:03 AM
  #40
Jpr5690's Avatar
tsp advised me to go 233\239 instead of ms3 to aviod fly cutting
Quick Reply: f14\15 vs g5x4 vs ms3 vs trex
