anyone running this cam from crane
228° 232° 112° .600" .600"
it is tunable with the crane cams tuner and that is a HUGE plus because i dont wanna bother with sending my PCM off and all that...and also there is no good dyno tuners around where i live...but i want a BIG cam to make LOTS of power N/A
I wish Crane/Vinci would use 0.006 lift for their published duration specs like the rest, rather than 0.004; it would really make comparisons with cams from other manufacturers easier.
So if you run a cam that needs to carry above those shift points, you're $hit out of luck.
what does this change?
at least I don't kiss my pistons all the time
