Cam swap, need help
#82
i think i was being pretty gentle, but i think it hit the block at the end, when most of it was out and i let the cam hang down (bad idea, i know i know) so i think it just rubbed up against the block
the bearings i think should be fine.
dudas35- do you believe i'll be okay to install the new cam tmr? maybe blow some air into there to make sure there isn't anything sitting on the bearings
i feel better now. thanks bud, i can sleep tonight
#83
Yeah, rubbing up against the block makes sense. If that's all it is, and you don't see any knicks or gouges out of the cam bearings, then I'd go for it.
Dudas - I forgot the sensor was encased in plastic, not just bare steel. I dunno what I was thinking.
![Smokin](https://ls1tech.com/forums/images/smilies2/smokin.gif)
#84
i believe thats it, since i was an idiot and let the cam hang down at the very end
the cam bearing closest to me has some light scratches in it, but that should be okay right?
#86
Dudas - I forgot the sensor was encased in plastic, not just bare steel. I dunno what I was thinking.![Smokin](https://ls1tech.com/forums/images/smilies2/smokin.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#88
fresh new day so i looked at the last bearing, closest to the front of the car
its scratched a little bit because of the lobs and stuff from taking out the cam. i know i have to be careful of deep scratches. I ran my fingernail over them, and it didn't get stuck, i could just feel the stratches. its at the bottom of the bearing, all away from the journals
should i be okay?
should i be okay?
#89
should i be okay?
should i be okay?
#90
i just rolled over 20k on the clock
i'm going to send a mirror back in there and make sure the other bearings are okay, cut apart the oil filter, and if everything comes back clean, I'll probably just move forward.
I think it was possible that a lobe cut some of the block, since aluminum is a lot softer than the steel cam. Like I said, shes still a pretty young motor, and i haven't noticed any problems with her, and I don't beat on it very hard
#91
#92
I will
thanks man,
I must say I am in love with your license plate. I'm thinking about getting that for my car (ohio), if its okay with you. Thats one of the best ones i've seen. Do you get a lot of people trying to mess with you though? Trying to race etc?
thanks man,
#93
ready to put the new cam in
but i'm out of synthetic oil (which is what a run)
is it okay to put regular oil on the cam when i put it in? or just wait until monday and buy some synthetic??
#94
well i'm going to wait until monday and do it right with my synthetic oil
so everybody is 100% sure I can start to take the springs off? even with the cam out? I don't see why it would be a problem
I'm going to use the air compressor method
#95
synthetic is compatible with conventional
#96
okay guys
the crank bolt i got from TSP in my kit is the stock length...how do i put on the cranky pulley now? i really needed the longer 120mm bolt i guess. and my torque wrench only goes to 200lb ft
and i think there might have been a problem with my order? there are new seats and seals, but i only have 17 seals??????
they are all the same size, the ls1howto says that the intake and exhaust seals are different sizes...but either way i have 17 of the same size seals? I'm confused now
#100
The seals are fine, on LS1howto.com it does specify 2 different types of valve stem seals, one for intake and one for exhaust but what you got are all exhaust seals which can be used on the intake and exhaust valves.
Jeff
Jeff
