What all comes with the Lunati 382 stroker kit?
Old Jan 16, 2003 | 07:29 PM
NA$TY-TA's Avatar
Default What all comes with the Lunati 382 stroker kit?
Like the questions says. I know rings come with it, but did everyone use those rings or use another brand? How about Rist pins?? How about Rod bolts?? Can you get it with lower copmp. pistons?? Who has a good price on this kit?? I believe Raging Motorsports had a good price but i cant find any info on there site. Thanks.
Old Jan 17, 2003 | 11:02 PM
ibjamin's Avatar
Default Re: What all comes with the Lunati 382 stroker kit?
Actually, the pistons come with -1cc valve reliefs. The -8cc dished pistons are a special order and using them will leave you with the stock compression ratio. You can get the pistons in either 3.898 or 3.903 sizes (for .005 hone)
The bearings are King. The rods are 6.125" long billet superlights. The pistons have a compression height of 1.123"
George E.
Old Jan 17, 2003 | 11:17 PM
DONAIMIAN's Avatar
I think the rings are original GM but im not sure, but im pretty sure they are <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 17, 2003 | 11:41 PM
NA$TY-TA's Avatar
So does that mean i cant get it with say a 9 to 1 compression to run with my ATI kit?? Who has the best price on that kit?? Thanks
Old Jan 18, 2003 | 12:24 AM
StevieZ's Avatar
The Lunati kit comes with everything. Pistons, moly rings, wrist pins, keepers, rod bearings, main bearings, rods and crank. If you buy it as a kit it comes fully balanced.
Pistons are -8cc and flycut around .100
Old Jan 18, 2003 | 12:48 AM
RUF SS's Avatar
You can get them in 9:1 compression ratio. I was told that you can call Lunati and they will give you 9:1 compression pistons for a minimal extra amount with your kit.
Old Jan 19, 2003 | 06:04 PM
StevieZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong> I think the rings are original GM but im not sure, but im pretty sure they are <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not any more. The 3.903 kit comes with aftermarket
moly rings.
Old Jan 19, 2003 | 06:08 PM
StevieZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ibjamin:
<strong> Actually, the pistons come with -1cc valve reliefs. The -8cc dished pistons are a special order and using them will leave you with the stock compression ratio. You can get the pistons in either 3.898 or 3.903 sizes (for .005 hone)
George E. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The -8cc now come standard with the 3.903 kit which is the only kit that they will offer soon . They are discontinuing the 3.898 kit.
Old Jan 20, 2003 | 03:13 PM
NA$TY-TA's Avatar
What is the average price to clean up the bore??
I believe i read somewhere that Lunati also has a stroker kit for the 6.0L block?? Any one know anything about that kit?? How about sponsers with good prices on the kit??
Thanks
Old Jan 20, 2003 | 04:19 PM
fast2001's Avatar
I would like to know if Lunati also has a stroker kit for the 6.0L block and who sells this kit. Anyone know? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 21, 2003 | 04:08 PM
NA$TY-TA's Avatar
So no one knows who has the best prices on these stroker kits. I thought the going price now was about $3500. any of the sponsers??
Old Jan 21, 2003 | 05:24 PM
theblur98ss's Avatar
I've seen the kits in the 3300 ballpark. They seem to be coming down. You may want to check out ramchargers. They had a good price on them not too long back.
Old Jan 22, 2003 | 12:45 AM
robertbartsch's Avatar
I thought the stroker crank could be had in several demensions up to 4.125 ...If installed in a 6.0 liter block that is a lot of cubes!
Unfortunately, these kits are very expensive when compared to other stroker kits for early model chevy small blocks.....
...these high prices have got to come down in time right?
