I reallllly f'ed up now...
Old 02-07-2006, 08:35 PM
  #221
00transamnh's Avatar
"IT got hard to turn because it was building compression. Nothing to be alarmed by."
Old 02-07-2006, 08:52 PM
  #222
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
God, this thing went on a full 40 posts since earlier!
Old 02-07-2006, 08:53 PM
  #223
SSPerformance's Avatar
man take it to a shop already......i read 12 pages of this **** and its still not runing
  #224
SSU's Drunk Typing Whore
Lithium's Avatar
Originally Posted by Z'mnypit
IT got hard to turn because it was building compression. Nothing to be alarmed by. Can you tell where the screeching is coming from?
Well the intake manifold was off still.
I could not pinpoint the sound...it did sound like it was coming from the inside the intake ports.
Old 02-07-2006, 08:57 PM
  #225
Z'mnypit's Avatar
That doesnt mean anything, the cylinder will still pressurize & if the plugs are in it, then it will get hard to turn till the air escapes. Only way to make it easy to turn over by hand is to remove the plugs.
Old 02-07-2006, 09:02 PM
  #226
Z'mnypit's Avatar
No one made you read it, if you dont like it then read the other threads. Were here to try & help him not criticize him. He made a mistake, something everyone has done. Get over it.
Old 02-07-2006, 09:05 PM
  #227
Z'mnypit's Avatar
I would pull the front cover to see if the cam & the crank sprockets are dot to dot. Did you check that when installed the cam? If you feel that its correct, then I guess either do the leak down test or ****** the heads to see if your having PtoV issues.
Old 02-07-2006, 09:09 PM
  #228
ArcticZ28's Avatar
Thank you for that fuel that I described earlier, which you obviously read about.
Old 02-07-2006, 09:13 PM
  #229
Lithium's Avatar
Yeah I am positive that is correct. I never checked after installing the rod bolts and removing the oil pan though...
But before leaving the towels in the pan I started it up twice and it ran perectly each time...idled on its own, never tried to die. Only thing that went wrong was no oil pressure. Thats how I ended up in this mess to begin with...no oil pressure.
Old 02-07-2006, 09:17 PM
  #230
Z'mnypit's Avatar
Then honestly judging by what you just said, I would check the rod bolts. Thats still im what Im stuck on. The timing isnt going to change unless you pulled the chain or cam.
Old 02-07-2006, 09:27 PM
  #231
zo6vetteman2003's Avatar
You would assume that the paper towels were restricting oil causing the little or no oil pressure. Did you use the SLP shim inside the oil pump pressure bleed off spring bore to increase the line pressure?
Old 02-07-2006, 09:33 PM
  #232
Lithium's Avatar
No I had no pressure the first time I started the car so I shut it off. Then I thought I installed one of the spacers backwards so I got it all back together and tried again...thats when I left the towels in there. So there was no pressure before the towels were even in there...
Not sure what that is...I just bought a ported ls6 pump from this guy and put it on.
Old 02-07-2006, 09:55 PM
  #233
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by zo6vetteman2003
oil pump pressure bleed off spring bore ?
Whhhhhhhhhhaaaaaaaaaaaatt!? Flux capacitor?
Old 02-07-2006, 10:01 PM
  #234
Lithium's Avatar
Hahahahaha what, you dont know what that is?
Old 02-07-2006, 10:03 PM
  #235
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It was just funny the way i perceived it!
Old 02-07-2006, 10:09 PM
  #236
Lithium's Avatar
LOL I have no idea what hes talking about either man...some other language to me.
Old 02-07-2006, 10:12 PM
  #237
ArcticZ28's Avatar
He's talking about the bleed off valve in the oil pump (shimming it is how you get higher oil pressure) and he's asking if you used an SLP shim.
Your answer is "I don't know, some other guy performed the porting/shimming work".
Either way, it doesn't pertain to this problem of knocking.
Old 02-07-2006, 10:18 PM
  #238
Lithium's Avatar
LOL thanks Artic
Old 02-07-2006, 10:24 PM
  #239
ArcticZ28's Avatar
Alright,, I'm not 100% convinced it's the rod bolts yet, but it's obviously a high possibility. Therefore you have two options of attack right now:
1) Do a compression test and check for compression in each of the cylinders to rule out bent valves.
2) Pull the pan again and check out the rods and rod bolts to see if anything is obvious there.
I would probably start with #1 as it's the easiest and you can rent a compression/leakdown tester from an autozone or something.
Old 02-07-2006, 10:42 PM
  #240
Lithium's Avatar
Cool. I ll do that then tommarow.
I am just sketching out about the other towel...where could it of gone? I mean nothing in the filter...nothing in the crank...nothing in the pan...
Quick Reply: I reallllly f'ed up now...
