Trick Flow Heads
Old May 18, 2006 | 06:02 PM
  #41
exSSer's Avatar
I wonder if you can use your stock rockers with these? You need an adapter w/ the ETPs @ 11* and these are gonna be 13.5*.
Old May 18, 2006 | 06:07 PM
  #42
TJ's Avatar
TJ
stock rockers, need different length pushrods ^^
Old May 18, 2006 | 10:19 PM
  #43
JZ'sTA's Avatar
true, 7.7" PR's
Old May 21, 2006 | 09:23 AM
  #44
DavidNJ's Avatar
Other than the flow number, I'm interested in the combustion. Some other TF heads, the Ford 'R's come to mind, have the plug seriously pointed toward the exhaust.
So more than the flow bench, I'd really like to see the results of these heads with a strong cam, like 224/228 LSK, and good intake. I'd really like to see the spark advance numbers, and maybe the amount of compression that could be tolerated.
Mike@TEA could chime in, do you expect these heads to require less advance and use more compression?
Old May 21, 2006 | 09:37 AM
  #45
skipperbisket's Avatar
you consider a 224/228 cam a "strong" cam? i wanna see what these heads do with a real cam, like a high 240 .610+ cam. what is the combustion chamber size on these heads?
Old May 21, 2006 | 06:54 PM
  #46
Hardtop's Avatar
With LSK lobes, it would probably be fairly "strong."
Bruce
Old May 21, 2006 | 07:20 PM
  #47
exSSer's Avatar
64cc, I believe.
Old May 21, 2006 | 07:48 PM
  #48
SSPerformance's Avatar
im considering these for my 408 but i wana see if anyone could get soem more cfm outa them
Old May 23, 2006 | 10:05 AM
  #49
Mike@TEA's Avatar
In the initial dyno testing results I have seen the head likes about 2 degrees less timing than our LS-6 heads, our 1.5-5.3's or the AFR 205's. As for compression increases I would not expect to be able to run alot more but the shallower valve angle should tolerate some.
Old May 23, 2006 | 04:53 PM
  #50
cws T/A's Avatar
what was the outcome on the dyno on the head comparo
LS-6 , AFR , 1.5-5.3's vs the TFS ?
Old May 23, 2006 | 04:59 PM
  #51
DavidNJ's Avatar
Mike, could you post a picture of the combustion chamber?
Also, TF lists the spring pocket at 1.45. Can it be cut for a 1.59 (like a Comp 26055 or 26095)?
Old May 26, 2006 | 11:02 PM
  #52
TAF Motorsports's Avatar
Old May 31, 2006 | 11:51 AM
  #53
Old May 31, 2006 | 12:58 PM
  #54
xfactor_pitbulls's Avatar
Seems like a bunch of smoke and mirrors. I hate when folks bring up product development 6-12 months before the product comes out. And right before it actually hits the market, there is always some sort of catastrophic set back.
Brandon
Old Jun 2, 2006 | 10:40 AM
  #55
Mike@TEA's Avatar
Here is a picture of the chamber nothing really new there. As for the spring pockets it should be no problem to cut them for the larger 1.55-1.625" roller springs. I was hoping some of the guys who we have shipped them to would post some pix or results but none have yet. I am told there is a huge batch of heads in process right now and availability should be very good in the next few weeks. We flew through the first batch pretty quickly. I will post power numbers soon.
Old Jun 2, 2006 | 12:59 PM
  #56
JNorris's Avatar
Moderator
Mike,
I will post up some pictures this weekend of the Trick Flow heads. I would have posted them earlier by my digital camera is on vacation with my wife.
I will start a new post with them in it.
I can tell you all that the heads are beautiful! The CNC work and attention to detail is some the best I have ever seen.
John
