241 or 243 or keep the 853 heads
Or, 243 castings from PRC (at TSP) or Patriot 243's or Livernois 243's look great also, all checking in from $850 to $1150. These have great mid lift numbers, and carry past 300 cfm around .600.
LS1 (Center Bolt)
99-00 5.7L Passenger Car and Corvette (853)
01+ 5.7L Passenger Car and Corvette (241)
Material: Aluminum
Combustion Chamber Volume: 66.67cc
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
LS6
01+ 5.7L Corvette
Material: Aluminum
Combustion Chamber Volume: 64.45cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
.100" 75 / 62
.200" 154 / 121
.300" 215 / 165
.400" 254 / 200
.500" 285 / 217
.550" 292 / 221
.600" 301 / 226
We can do you a set of these bare for $845 or we can assemble them with 2.00"/1.55" OEM valves and LS6 springs for $865.00. If you use these heads, it will yield a 10.5-1 compression on a stock LS1 bottom end. We can also do any additional milling to these at no extra charge. If you have any questions, please let us know.
I agree for the most part.
Unless you have TEA run the program said above.
The LS6 option is a damn good one, and for as cheep as it is you cant go wrong.
Also the 241's and 853's are the exact same after porting.
