T-rex
Old Jan 16, 2006 | 04:42 PM
jow02327's Avatar
Default T-rex
ok here's the deal i am building my ls1 up to make as much N/a power as possible. but i dont want to wait to do everything at once. here are the plans
next week Moser 9" and 255lph fuel pump.
with this could i put the T-rex cam, dual patriot springs, TT retainers, l-7 locks, beefer pushrods. in with the stock heads and intake and see pretty good numbers? i am planning on going to Fast90 intake and TB or Ls2 intake and Fast 90 tb w/ bigger injectors and AFR 205 or 225. i am wanting to make as much power as possible so you guys tell me what yall think.
Old Jan 16, 2006 | 05:35 PM
jow02327's Avatar
someone has to have done this before
Old Jan 16, 2006 | 07:44 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
you should see ball park 410 rwhp and around 39X tq. Thatis assuming you have some supporting mods and are an M6.
Old Jan 16, 2006 | 08:32 PM
jow02327's Avatar
full bolt ons, through M6
Old Jan 19, 2006 | 10:35 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Sounds about right then.
Old Jan 19, 2006 | 10:44 AM
little tee rod's Avatar
Default t rex numbers
410 rwhp power seems a bit low i would have thought it would make more power than unless that is through a 9 inch or 12 bolt!
Old Jan 19, 2006 | 10:51 AM
00BlackSS's Avatar
he said hes going through a 9inch as stated in first post.....
410 is a little low....but thats prob. with no tune or a decent street tune....no full out race tune
oh ya....put that TNT F2 on ur WS6!!
Old Jan 19, 2006 | 11:13 AM
i see my fault not paying attention how much would it make through a 10 just curious!
Old Jan 19, 2006 | 03:26 PM
00BlackSS's Avatar
its not going to be a huge difference...Thunder saw 451....im not sure if thats through a 10 or a 9inch or 12bolt
Old Jan 19, 2006 | 03:34 PM
CRL 01 SS's Avatar
The 9" will probably cost him about 10-15 rwhp from 10 bolt numbers. I'm pretty sure that Thunder put the 451 rwhp through a 10 bolt.
Old Jan 19, 2006 | 05:32 PM
Cop Car's Avatar
do the t rex killer, have to fly cut your pistons and replace lifters, but thats not a big deal for you since you will be taking the heads off anyways
Old Jan 19, 2006 | 06:16 PM
jow02327's Avatar
yeah for know i am doing the Trex afr 225 through a moser 9in, 410 gears and a full dyno tune by Nelson or TSP
the F2 kit is going on the truck for a little while. i want to make 500 on a stock bottom end 5.3 w/ stock ls1 heads and also to see if the stock tranny will hold over 450
Old Jan 19, 2006 | 06:21 PM
Josh's Avatar
Actually, he shouldn't have to do either of those things.
Josh
Old Jan 19, 2006 | 06:35 PM
s346k's Avatar
it says that the cam "shouldn't have ptv issues with unmilled factory ls1/ls6 heads"...which means it is worthy of consideration for a cam
it does say that "comp r lifters are required"...but from what i've read, we'd be better off sticking with the stock rockers as the comp rs have been problematic.
Old Jan 19, 2006 | 06:49 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is because people are not setting them up properly. Not because they are bad.
Old Jan 19, 2006 | 06:51 PM
Josh's Avatar
Where did you read that?
Josh
Old Jan 19, 2006 | 06:53 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You do realize that he is talking about Joe's cam....not the Thunder cam.
Old Jan 19, 2006 | 07:00 PM
SSilverSSurfer's Avatar
theres a vid of red camaro with trex and LS6 heads with 45xhp....but i guess thats right through a 9inch
Old Jan 19, 2006 | 08:14 PM
Ωmega's Avatar
I was waiting for someone to say that... that cam is called the "T-Rex Killer" but I don't know much more than about it than that.
The T-Rex works fine with stock pistons, heads, and lifters. I know this first hand
I'm not sure if you said it before, but do you have a set of long tubes? You said you'd be putting it in with the stock intake still, but you mentioned upgrading that which is good. But if you don't have headers, get them first!!!
Old Jan 19, 2006 | 09:30 PM
00BlackSS's Avatar
they ran that 10.xx pass in that 10bolt to??? thats crazy!!
