The jury is in: ET 245cc 11* valve angle flow numbers inside!!
Well, I just got confirmation. The heads are fresh off the flowbench. The results were not as advertised, they were better. They were flowed on LME's Superflow SF600. Needless to say I'm elated. The mid flow numbers are outstanding. Big thanks goes out to Cary on a product that delivers as advertised. The heads choked up past .675" of lift as advertised. The exhaust flow numbers are especially good. The motor leaves Houston on friday guys. I can't wait.
The heads were not off the shelf 245's. I had them milled down to 62cc and 2.08/1.60 valves used as opposed to the standard 2.10/1.57 valve combo it uses for it's advertised numbers. The valvetrain is also upgraded(springs/retainers). I kinda wish I would have opted for the titanium valve option, but another 600-700 bucks.....I can live without it.
4.0" bore @ 28" H2O
Super Flow SF600
Intake flowed with a radiused inlet. Exhaust w/ no pipe.
INTAKE
Lift Actual Advertised Variance
.100 71 73 -2
.200 144 152 -8
.300 220 210 +10
.400 279 266 +13
.450 303 XXX XXX
.500 319 312 +7
.550 332 327 +5
.600 338 338 0
.650 340 346 -6
.675 341 XXX 0
Avg. 255 253
EXHAUST
.100 57 57 0
.200 111 114 -3
.300 154 164 -10
.400 212 204 +8
.450 227 XXX XXX
.500 236 224 +12
.550 243 228 +15
.600 247 231 +16
.650 251 234 +17
.700 253 236 +17
Avg. 196 188
Cost of heads: $3000+
Wait time: 5-6mos
Look on my face when I see over 300cfm at .450 lift: priceless
4.0" bore @ 28" H2O
Super Flow SF600
INTAKE
.100 71 73 -2
.200 144 152 -8
.300 220 210 +10
.400 279 266 +13
.450 303 XXX XXX
.500 319 312 +7
.550 332 327 +5
.600 338 338 0
.650 340 346 -6
.675 341 XXX 0
Avg. 255 253
EXHAUST
.100 57 57 0
.200 111 114 -3
.300 154 164 -10
.400 212 204 +8
.450 227 XXX XXX
.500 236 224 +12
.550 243 228 +15
.600 247 231 +16
.650 251 234 +17
.700 253 236 +17
Avg. 196 188
Wait time: 5-6mos
That's what she said...
Congrats on the heads! I hope this company gets going alot better and makes these things easier to get ahold of! I've got a feeling with the new stuff from world and heads like these, the LS1 is going to start getting outrageously mean. I'm glad I got in on the ground floor
Anyway, here's what 4:28 am gets you! I LOL'd at your last comment so much I just couldnt resist
LS1TECH Sponsor
I can't say enough about the quality of the ET cylinder heads. The flow numbers are excellent for just popping two springs off and putting them on the bench. Our bench is actually right on. It is regularly calibrated with the Super Flow calibration plates. When we flowed a set of the ET 265's they were one CFM off of what they told us they flowed. Our bench read 373 CFM @ .650" & ET's number was 374 CFM @ .650"
In any event, the ET heads are bad *** & should make some killer power!
The only reason I guessed your bench was a little high was because Ive seen 2 sets of heads flow very high there and make very average numbers once the motor was put together. Just guessing.
Bryan, G-Force has my 408 from you guys right now. I`m waiting on a set of 245`s and i will be running. I really look forward to seeing the power this thing is going to make. Can`t wait. Thanks for the 408!
10 Second Club + 14 Second Truck Club
am i missing something or are the 245's not on the et site. i can only see the 215's, 225's, 240's, 255's, and 265's.
i have a set of 240's ordered and am patiently waiting for them to sit on top of my 421 stroker.
i plan on going with the 255s myself for my 408 unless someone talks me out of it
Originally Posted by kumar75150
ya i was just thinking that earlier
unless this is a solid roller high rpm motor i would be worried about the heads being a little soft for street use. the 240 would probably be a better choice for a street motor.
i come from I4 Hondas so a 408cid V8 and 3.90s already roasts the tires everywhere. Im just interested in power where I will be racing in.
