Whos the most reputable engine builder on this site?
Stand up guy! I havent got the motor yet, but thats due to parts from comp being on backorder.
Im dealing with him long distance, mainly because everyone I talked to locally couldnt instill the confidence that Harold did. This guy calls or emails almost everyday to let me know how things are coming. He's also ported a set of LT1 castings for me, they flow more than the AFR 195cc heads I was going to buy.
Definitely shop around, if you jump into a deal with someone too quick, you may find yourself regretting something.
That being said, if you are looking for something to handle ~800hp I think that any of the mentioned shops can handle that...if you are going to be looking for more then W2W. I doubt any company has produced more LSX engines that have made over 1000rwhp then them.
YES...Katech should be in the running with their track record with the ALMS C5R & C6R Corvettes. They supply the engines to Pratt-Miller ..ie the factory Corvette team and have done a ton of R&D work with the LS series engines....There are many good engine builders around the country..You can also buy the short block or long block from a competent source and have a good local shop to the installation for you...
https://ls1tech.com/forums/generation-iii-internal-engine/443165-internet-diagnosis-anyone-need-mech-s-help-here.html
https://ls1tech.com/forums/showthread.php?t=443165
https://ls1tech.com/forums/southern-members/435378-nc-guys-brandon-matt.html
Their 441 in a C5 was the first N/A C5 in the 9's
Their 346 is in the fastest Z06 with TT's running 8.4's and no reliability problems.
Their 427 in a Z06 is the fastest 6spd N/A Vette @ 10.1
CARTEK also has a few road race 427's running 45min at a time at 6000rpm w/o probems.
What ever your LS1/LS2/LS6/LS7 needs CARTEK will help you get there!
Ask for Dave 908.317.4496
