Is anybody runing a 372 or 375 with.
Old Jan 17, 2003 | 04:10 PM
jleews6's Avatar
Default Is anybody runing a 372 or 375 with.
I never see anybody running this combo.It is cheap to do and would be strong.It should put good hp numbers to.How come i never here of anybody with it?
Old Jan 17, 2003 | 04:47 PM
BradWS6's Avatar
Default Re: Is anybody runing a 372 or 375 with.
I'm running a 372 stroker..used a Scat Crank..Square Motor..It was cheap to build.I'm running a solid roller set up with ported LS6 Heads and 1.9 Rockers..Tore the motor apart trying to find why my trap speed was 119MPH.The bottom end looked great..spun the motor to 7500RPMs.My Heads flowed terrible.I know where the problem lies <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I'm now leaning towards a sponcer on the board for better heads.This car should run easy 10's here soon <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 17, 2003 | 05:34 PM
Samba242's Avatar
A lot of the Mallett Corvettes run a 372 LS1 stroker motor. 3.90" bore X 3.90" stroke right? "Square" engines are supposed to be pretty tough aren't they?
Old Jan 17, 2003 | 08:39 PM
jleews6's Avatar
I was thinking more like a stock crank with a .030 or a .060 6.0l block.I think the 4030 bore would make good power.It seems to be common to make 420 rw with a heads and cam setup so a 372 "should make 15 to 20 more hp with more tourqe and a longer rpm spread. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I have GTP stage 2s and i think im going to put them on a 372.
Old Jan 17, 2003 | 08:43 PM
turbo'd stang's Avatar
I had looked at doing the same thing, a 6.0L block, .040 over with the stock crank and maybe some longer rods..depending on piston deck. I would love to do it, but I have to sell my car soon, so......let me know how it turns out.
Scott
Old Jan 18, 2003 | 10:07 AM
jleews6's Avatar
Nobody runs this settup? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 18, 2003 | 10:33 AM
RyanJ's Avatar
SSU Moderator
Joe runs a 370" and spins the crap out of it.
Old Jan 31, 2003 | 11:53 AM
dug's Avatar
dug
It would be cool to start with a 6.0l engine with the good heads. Its hard to get past the weight penalty.
Old Jan 31, 2003 | 01:21 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We're working on a few packages like that, I am going to be running a 4.060 bore in my 396 setup.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
