What cams are you guys running with .030 milled AFR 205s and uncut pistons?
Originally Posted by tru_ice
I'm just about to order a set (61cc) w/ .040 gaskets.
I'll be running them w/ 228/288 .588/.588 114. That should put my CR right at 11.1:1, w/ a quench of about .033.
What do you think Tony? Does that sound like an adequate setup?
Originally Posted by CKZ
With a stock shortblock, unmilled AFR 205s, and .04 Cometics..what will compression be?
Also, how will this fare with a 224/228 .581/.588 112 cam
Thanks![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks
Originally Posted by Ksett
I'm getting 11:5 with no valve reliefs cut.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
http://www.c5frc.com/calculators/Com...Calculator.htm
http://www.rbracing-rsr.com/compstaticcalc.html
This is the correct link
The other doesn't account for the piston OUT of hole situation which should be entered as a negative value.
#32
hey guys, im thinking about getting the afr 205s and then milled to 030, but im looking for 430rwhp. What Cam is good, im glad i caught this thread. is that possible, it seems you can only run a cam at around a 224? i wanted a 112 lsa though.
#33
It will easily make the power you are looking for, especially if you mill the heads for additional CR. There are dozens of independent results with that cam making the power you are looking for.
Tony M.
