TSP Magic Stick or TSP 231/237?
My impression is that the Magic Stick essentially has 231/237 characteristics, but on steroids. I really enjoyed the 231/237. It was a great cam. But given a choice between the two, I'd go with the Magic Stick. Only factor swaying a decision towards the 231/237 would be spring life, as the lunati lobes are a bit lazy and are pretty easy on springs in comparison to today's aggressive grinds. Either way, a good tune is in order. Also, no need for an adjustable timing set, just get a new one to freshen things up.
The 231/237's lobes are softer, therefore the interval would be longer.
Do the Pacesetter headers over the SLP garbage.
I installed a cam in my car recently at 106K...no problems and pulls like an animal up top. I do recommend getting the LS6 oil pump and LS2 timing chain as well as the dual springs kit and hardened pushrods. Just make sure all the little things are up to date also such as plugs, wires, air filter, fuel filter and the mileage won't effect your gains.
1200 bucks is rape for that system (not because of the price, but because of the headers themselves, but then again, yes, they should not cost that much in the first place).
If you're going to spend that much money, Dynomax Supramaxx catted kit is the way to go for a comprehensive setup.
My vote goes to QTP HVMC LT's ($750 for the best flowing headers out there, stainless steel) or KOOKS with a catted Y-pipe, which is no different than the SLP setup in terms of components you get for the "kit".
Stay away from SLP.
I got rid of the 231/237 in my car and put a MS3 in instead. It pulls a lot more up top and pulls a lot longer, and I also changed my gears from 4.10s to 3.73s.
