big cam without killing the springs
[EDIT] Even though the TR224 isn't a huge cam, it can make a ton of power. If you decide to throw a few more mods on, you'll be shredding tires in no time.
The TR224 seems like a very popular cam for people with stock heads. Thanks for the suggestion.
There are lots of bigger cams, but you would get disappointing results. Until you do a few mods to increase air flow into and out of the engine, a bigger cam would be choked off from making the power it's designed for. Also, bigger cams make their power higher up in the RPM band. For example, your current rev limit is 6000; and your stock valvetrain can handle that. A big cam probably tops out power-wise from 6400-7000, and even higher for some. You would have to upgrade a lot of valvletrain parts and probably Connecting Rod Bolts (Piston to Rod connection) to handle the increased RPM without floating your valves.
If you stick to stock intake, heads, and exhaust, then going bigger is not better, just more expensive. Picking one of the cams I suggested, or maybe the CHEAtr (designed to work with staock exhaust & intake) cam would be best. Some people start off with a cam swap, but most start by doing a ton of mods that add power now, and prepare the engine to take advantage of a big cam. Here's how I did it:
1) Cold Air kit and lid (get rid of those stinking baffles)
2) K&N Filter
3) 85mm MAF Sensor
4) 160-degree Thermostat
5) Loudmouth Exhaust
6) Tuned Long Tube Headers & High Flow Cats
7) TR55 IX plugs
8) Spiro Pro wires
9) DiabloSport Predator Tuner
10) 4.10 Gears
New clutch, master, & slave plus new rearend girdle go in this Month
Already working on the heads; will get one of the following cams probably: Futral F14, TR Magic Stick v3, TR Torquer v2, TR 231/237. I'll be getting dual springs with the cam, but I'll still have to check them every 20K miles, if not change them that often... once a summer.
There's nothing that says you have to do it this way. this is just my opinion. The quickest way to a quicker car might be to install 4.10's first then a medium cam that your stock motor and valvetrain can handle...
[EDIT] sorry, the losers running the dyno didn't print out the A/F. I would really like to know myself. I also wish the Predator showed A/F, but it doesn't...
Also, note these numbers are from a Mustang dyno, and would be even higher on a more generous dyno...
Ill have stock heads that will be ported. Which casting is better 853 or the 23...other ones....lol
The 853's are the lq9 heads right? So those would be the better of the two?
The numbers in the cam suggested [EDIT: 224/230] favor the exhaust duration (230) to make up for lower flow. Good suggestion...
If you're sticking with the stock manifolds, go with a reverse split cam as suggested with longer exhaust duration to work with the restrictive manifolds.
