Bent pushrod or valve?
Anyways, I did the idiot shift of 3rd to 2nd while meaning to put it in 4th, at WOT. Don't make fun of me, I have already done it to myself. So, I pulled all the pushrods(stock) to check them. None of them were visibly bent. I rolled them on my counter, and all seemed to roll fine. I bent down so my eyes were level with the counter and watched the holes on the ends of the pushrods. There were a few of them that wobbled just a tiny bit, so I switched those out. Were those pushrods bent?
My concern now is, if those werent bent, did I bend a valve? I don't hear any ticking or anything.
Lucas, from my previous experience , I am 100% sure that u bent some valves if u visually checked the pushrods and looked fine.
Pm me for more details.
If the engine is over-reved the pushrods will bend. Unless your pushrods had some serious issues the valves SHOULD be just fine. How high did you redline?
You would HEAR something, probably more than a lil' ticking which all LS1's do.
If you take the heads off without buying ported heads to put on you're going to kick yourself for doing all the work for nothing. Have a leakdown test performed. I don't think you bent 'em though. -Joshua
On a shift incident like this, how likely is a fraction of a second over rev to cause a rod bearing to spin? My engine has about 40k on it and still runs nice high oil pressure at cruise.
Sorry to hijack, but this is something I have been wondering about as well.
I would say this is a 99.9% a bend valve .
u need to do a compression test , mine was = 0 at piston 8 .
I'm about to go search prostock_bigblock's old threads and see what I can find.
