Help Big Problem!
EDIT* Misread the post.
As for your lid issue, I'm guessing that they are gonna scan your car and come up with a lean bank one, lean bank 2, because while the lid was off the MAF got dirty, and isn't reading right, causeing unmetered air to make it into the motor. Get a new clip from the dealer before you even have the car scanned, and while you haev the lid off, get some carb clean and hose the maf out really good, to make sure it's clean, and you mine as well pull the TB too and clean that. If the clip did get sucked into the motor, which I doubt, but if it did, it will be sitting at your MAF screen, and if you have no maf screen, then it could have made it into the motor.
For all you guys that remove the maf screen, let this be a lesson, this is a perfect reason not to remove it, that and it doesn't realy help to remove it, other then making the MAF not read properly.
