Whining Noise After Cam Change
Old 02-26-2014 | 11:10 PM
  #241
mchicia1's Avatar
New cam retainer plate came. So this is how THICK the gasket is supposed to be? Holy ****, I bet I have been having oil pressure leakage this whole time. It's the original from '99 LOL and I've had it off probably 10 times.
My cold oil psi was only around 47, which I didn't like too much.
Got the cloyes timing set too.
Not messing around this time. I don't want to do this install again for a while!
Old 02-26-2014 | 11:12 PM
  #242
mchicia1's Avatar
Originally Posted by z28SSilvest
I've had that same noise come from my BRAND NEW LS3 with a hot cam in it that came cammed from GM. It sounds like the alternator to me because it only happens like 1 time every 3 months.
Can't possibly be a bad cam.. unless GM screwed up on installing it.
Yours is probably a different issue then. We already proved in here the cams are causing the noise. We are past that point already.
The difference with ours, the noise is 100% constant. Cold/Hot/with 0 miles on the cam/with 10k miles on the cam. Noise never changes. Cams look perfect to naked eye. Only special machinery can pick up the issue.
It is not an install issue either, it's a manufacturing issue.
Yours is prob power steering or alternator.
Old 02-27-2014 | 12:01 AM
  #243
z28SSilvest's Avatar
Originally Posted by mchicia1
Yours is probably a different issue then. We already proved in here the cams are causing the noise. We are past that point already. The difference with ours, the noise is 100% constant. Cold/Hot/with 0 miles on the cam/with 10k miles on the cam. Noise never changes. Cams look perfect to naked eye. Only special machinery can pick up the issue. It is not an install issue either, it's a manufacturing issue. Yours is prob power steering or alternator.
Sorry about that lol. Dont have the patience to read through 17 pages .
Old 02-27-2014 | 12:23 AM
  #244
mchicia1's Avatar
I don't blame you. It took all 17 pages to get to the bottom of it too. It wasn't an easy problem to figure out.
I had to tear my car down twice to figure it out.
Old 02-27-2014 | 01:40 AM
  #245
4kiro's Avatar
I just got a cam from Comp Cams through Tick, hopefully they have fixed this issue. We shall see.
Old 02-27-2014 | 05:57 AM
  #246
joshua022's Avatar
Kip offered a few pages back to regrind anyone's cam in here.
I would have just sent it to him tbh.
He charges $200.
COMP is doing it for free.
If this doesn't fix it then Ill buy new from kip.
Old 02-27-2014 | 06:21 AM
  #247
KCS's Avatar
KCS
Moderator
Does anyone bother checking end play?
Old 02-27-2014 | 10:01 AM
  #248
mchicia1's Avatar
Originally Posted by joshua022
He charges $200.
Ok worth a shot then, good luck with it.
Old 02-27-2014 | 10:48 AM
  #249
joshua022's Avatar
I thought about that but don't have the dial indicators to check it.
Old 02-27-2014 | 11:00 AM
  #250
Coonass350's Avatar
17 pages? All its showing for me is 13
Old 02-27-2014 | 11:10 AM
  #251
mchicia1's Avatar
You can configure posts per page.
  #252
mchicia1's Avatar
It's a lobe issue, not an end play issue anyway.
Old 02-27-2014 | 11:48 AM
  #253
KCS's Avatar
KCS
Moderator
I'm still waiting for the issue to be proven. All I've seen are assumptions.
Old 02-27-2014 | 11:53 AM
  #254
mchicia1's Avatar
Um, no, they are not assumptions.
1) Lunati already verified, my cam was sent to them. I have two whining cams from them.
2) The whining noise went away upon swapping to a cam motion cam.
3) Kip already knew about this issue a decade ago and he put his research a few pages back.
Old 02-27-2014 | 12:04 PM
  #255
KCS's Avatar
KCS
Moderator
What was the issue then? All I've read is that QC caught "something" but as far as I can tell, it's assumed its the same issue Kip had years ago with the surface finish of the lobe. Someone else had mentioned their cam was rubbing on the rear cover.
Old 02-27-2014 | 12:09 PM
  #256
mchicia1's Avatar
I'm the only one who has sent a cam back so far and been through an inspection. It's a lobe surface problem, which may or may not hurt anything. I have heard conflicting info on this so far, but I won't take chances.
The one guy in the video I found, which helped start all my research into the issue, did say his cam was rubbing, but I think he was making assumptions.
The one thing you'll find in all the videos I found and the ones we made, is that all the whining noises sound dead nuts, exactly the same across all our cars.
Also, there was no wear anywhere on my cam, front cover, or retainer plate.
Old 02-27-2014 | 12:25 PM
  #257
KCS's Avatar
KCS
Moderator
So Lunati told you it's a "lobe surface problem"? Is that the extent of their explanation?
Old 02-27-2014 | 12:57 PM
  #258
mchicia1's Avatar
No, that is my summary of it.
Their explanation was very thorough and over my head, but it was related to the lobes, yes.
They reground and repolished the cam.
Old 02-27-2014 | 07:05 PM
  #259
Colt45's Avatar
I've sent my cam to comp. Greg called me today and said the cam finish was well below there tolerance. .002. Re polished anyway to .001 and is overnighting back to me. He states it was well below gm spec also. Tho my stock cams have a mirror finish. He seemed really helpful. The cam looked fine when I sent it to them. I'd post pics but my I phone won't post them. Looks like I'll find out Friday or Monday what this re polished cam looks like.
Old 02-27-2014 | 07:12 PM
  #260
mchicia1's Avatar
Do you mean they were saying it was within spec?
Quick Reply: Whining Noise After Cam Change
