224 vs 228
Old Mar 1, 2006 | 01:23 AM
ramsoccer11's Avatar
Default 224 vs 228
ok so after a little research i had decided that a 224/224 cam (the tsp package w/ 918 springs to be exact) sounded like a good idea. i was just going to get the xe so i wouldnt beat the springs to death with the bigger lobes. but the more i look at it the 228 starts to call me. im not trying to build a drag car, just something to have fun in a drive on a daily basis.
my question is, would it be worth it as far as power gains to get the bigger cam or am i going to just end up tearing up springs quicker for a few extra ponies?
btw id prefer not to go w/ double springs.
Old Mar 1, 2006 | 01:50 AM
crazy camaro's Avatar
word of advise DON'T CHEAP SHOT VAVLETRAIN!!!!
Old Mar 1, 2006 | 07:19 AM
slow trap's Avatar
the 918s should last for quite a while with the 228/228.go ahead and splurge !
Old Mar 1, 2006 | 07:58 AM
4mula's Avatar
both will make about the same power. the 228 will just make it in alittle higher rpm range compared to a 224.
get dual spring.
Old Mar 1, 2006 | 08:40 AM
GuitsBoy's Avatar
Why dont you want a dual spring. Patriot golds can be had quite inexpensively, and theyll last quite a while on a mild lobe, plus youll have the protection of duals. Unless you specifically dont want the weight in the valvetrain. Also, go bigger on the cam! Just my opinion.
Old Mar 1, 2006 | 10:30 AM
8GTOKLR's Avatar
At least upgrade too Dual springs for cheap insurance. Its a while you're there kinda thing
Old Mar 1, 2006 | 10:41 AM
i guess it couldnt hurt, i was just told that the 918s would be plenty of strength. has anyone ever had any problems w/ these?
Old Mar 1, 2006 | 11:36 AM
91z28-350's Avatar
918s should be good enough for the XE lobes.
Old Mar 1, 2006 | 11:41 AM
IrateTA's Avatar
the 918's should be fine... I was advised to get them for my TR224 w/ XER lobes.
Old Mar 1, 2006 | 02:08 PM
99zman's Avatar
so there is no real gain in power form a 224 to a 228??? if they make the same power but the 228 is up higher why would anyone want that?
Old Mar 1, 2006 | 02:44 PM
GuitsBoy's Avatar
its funny that theres little difference between a 224/224 and a 228/228. But if you step up to a 230/232, there are many accounts of people reaching 400+ RWHP, cam only.
Old Mar 1, 2006 | 02:51 PM
DannoWS6's Avatar
918's on a 228/228
yup, thats what I got.
Old Mar 1, 2006 | 02:56 PM
LPTXZ28's Avatar
I am also running 918's and stock retainers with my 228. So far so good. Has survived amny bumps off of the 6700 rev limiter.
Old Mar 1, 2006 | 03:13 PM
Redneck Z's Avatar
Lots of people make 400 rwhp with the 224/224 also.
Old Mar 1, 2006 | 03:24 PM
1LoudTA's Avatar
fms f10 228/228 .576/.576, comp 918s, stock retainers, shifts 6600rpm
Old Mar 1, 2006 | 03:29 PM
Rescue Ranger's Avatar
hehe i couldn't decide which either, so I went with 224/228.. lol. I definately went w/ dual springs.. its cheap insurance man.. and you'll never have to think about how you're valve springs are holding up.
Old Mar 1, 2006 | 03:30 PM
GuitsBoy's Avatar
With stock heads?
I guess its possible since there have eveb been 400 RWHP stock internal cars out there. Although it does take a few exotic bolt-ons...
Old Mar 1, 2006 | 03:38 PM
Ryan02SS's Avatar
With stock heads?
I got really close cam only...... Lid, ASP, PTB, YT 1.7s, TR224 112LSA, JH LTs, Hooker ORY w open QTEC, helluva tune from Mikey @ Rapid... Stock 241s
PS's dyno is also noted for being a little on the stingy side.
Click Me
A 228 on the same lobes as the 224 with similar valve events should mirror each other with the 228 pulling 5-8rwhp up top over the 224 and the torque curve holding on a little longer.
Old Mar 1, 2006 | 03:40 PM
~JOSHUA's Avatar
I've got the 918's and they are great. You wont have to change as often as the dual too. Plus, the inner springs on the duals break easily if you happen to blip the throttle before the metal is warmed fully. The 918's are good for well over .600 lift. Then after the Comp 921 springs came out they had to "officially" rate the 918's at .600 so they wouldn't lose business on the 921 buyers...
I had the 224 cam and I wanted more after a couple months. I then went to the 236 I have now and it's still not good. I'd go ahead and just get something in the 230 range, they drive the same.
I can't tell the difference (drivability)between the 224 and 236. They 236 makes insane topend though, and there really isn't much low end loss. I break traction anytime in 1st or 2nd gear and if I floor it above 4,000prm in 3rd it lights up. A cam in the mid 230 range with bolt ons will garauntee 400+ rwhp -Joshua
Old Mar 1, 2006 | 03:55 PM
Billiumss's Avatar
Exclamation
I've tuned a few 224 cam only cars, I'll have to call out the BS flag on that one..... there it is. The cars I tuned had every bolt on except electric water pump.
The power range was 375-385 RWHP
