If you run a futral or comp XE-R cam then come in.
Futral FM13
PRC dual spring kit
7.35 push rods from Trick Flow
Comp 850 lifters
stock heads (mild port work)
2500 miles since the install
Purchased I beleive in May or June.
I am about .75-80 with 7.35 PR's, I have to look it up were it came out at. I have yet to look at he cam since I have less than 5k miles on it.
No problems that I am aware of, and hope none arise with more mileage.
55K+ on stock lifters, 30k of it with a hot cam and 1.8 Rockers. 10K with LS6 springs, 15K with 918's the rollers are perfect!
PRC dual spring kit
Comp 850 lifters
Originally Posted by redtail2426
I want to get a poll and try to figure out what some of these lifter failures are all about,lobe texture,lifter side load,stock lifters,whatever.So answer the short ??'s below and maybe we will get somewhere.Most importantly is how many miles you have on the setup.
1) What Cam are you running (Futral,comp xe-r) and tell us the specs.
Futral F13 112 LSA
2)What valve springs,just say dual or single if you want.
Manley duals
3)What lifters
Comp 850, new with cam
4)how many miles are on your cam and lifters.
about 4000
5)Any failures?? tell us what ya broke,if anything.
Futral F13 112 LSA
Manley duals
3)What lifters
about 4000
1)mti stealth 2 224/220 .581 116lsa
2)manley nextex singles with titanium retainers
3)stock lifters
4)about 8-9k on cam
5)no failures yet
3)stock lifters
4)about 8-9k on cam
5)no failures yet
